An update on my TD05H-18g adventure:
Installed the Kando T518Z copy today on a SR20DE+T along with a Kando SR20 manifold. The manifold was really high quality for what its worth, changed the entire sound of the car now. The TD05-18g went on without any drama, replacing the OEM S14 T28. All lined up perfect ETC.
The driving experience surprisingly has not changed dramatically. Under 2000rpm there IS a notable loss, however you only notice this when creeping away at those revs. Any level of spirited drive has a near lossless experience.
I would say the T28 is entirely progressive in its delivery, packing its best punch just before 4000rpm. The 18g seems to have equal effect from 2000rpm to 3000rpm, from 3000 to 4000 you get a significant increase in pull from the T28 and at roughly 4000rpm the power comes in thick and strong with a 'full song' effect.
I am very impressed with it so far, am very much looking forward to the full tune with double the boost.
What power are u hoping for Jase?
I have an S14 thats looking to upgrade from stock. Maybe this is what he needs.
Being Nistuned by Unigroup for this one, expecting to see 240rwkw BUT am hoping for over 250.
Have seen a couple of these doing 240rwkw with very respectable boost (16-18psi). As you know Im pretty gung ho so Im going to have them turn up the whick on this one until it starts to cap off.
I would put it as a little laggier than a disco, yet making GTRS power. For the record the delivery absolutely shits all over a GTRS and I'm expecting it will make the same power.
well to give you a idea i had a kando td05h18g on my 180sx sr20det non vct tuned by unigroup on 19psi by 4200rpm and made 231rwkw
^^^thats sounds like HKS 2530 numbers, response samish aswell
cheers
darren
Really? I get the same boost response and more power from the bigger TD06-20G on an RB20 and people are forever telling me the SR spools turbos better then the RB20
Well its typical to what i have personally done and seen on others..Rb20 wise i have no idea, haven't had anything to do with them, i don't even like Rb25's..lol, to laggy... i like
sohc forklift motors..lol
cheers
darren
Edited by jet_r31
What gear and what boost?
This is an old dyno sheet of an old tune...but paints the general picture. This is without en EBC, just straight off the gate with a bleed
But generally speaking I make over 200rwkws from 4,500rpm and in 4th gear the gate opens at 4,000rpm
Well they better be ready to man up because I want more than that lol
was the 8cm i reckon on a few more psi of boost and it would of cracked 250rwkw but i didnt try as i only had 555cc injectors and had it up to 237rwkw same boost but tuner finished up on 231rwkw and it backed it up at wsid quarter mile running a 12.5 at 117.9mph with a shit 60ft of 2.19
when i changed it had barely any preload on the actuator so thats why it was a bit lazy on to boost
so its definately very similar in power output to a t518z which its the same as
my brother made 240rwkw on 21psi but with the greddy t518z
so if you really want to crack 250rwkw be willing to run above 20psi the suggested boost is 1.5bar anyway
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
