T67-25G uses the same L2 turbine wheel as the TD06L2-20G
TD06H-25G uses a 67/58.8mm 11 blade turbine wheel
the TD06H-25 is very similar to a Garrett GT3576 in size with only a couple of mm in it.
compare that to the 61/54.1mm turbine wheel of the L2/T67
now there are a bucket load of variations of the MHI turbos such as what MHI call the Super 20G or the TE06, all very similar, but different enough to cause headaches when buying from the likes of kando, the the shaft sizes and wheel trims vary
eg Kando sell a T67-24V a TE06H-25G etc, even sell the Large 67mm turbine wheel equipped turbo fitted with a 20G compressor.
So be wary, and ask before handing over your cash.
check my TD06 thread for more info re: wheel sizing etc
Ok I understand now the t67 has the l2 turbine but a 25g compressor correct
Yes.
Greddy called it a T67, as effectively it is a TD07S and a TD06L2 joined together using the 4" inlet TD07S comp cover with the L2 turbine housing and centre section...kinda like a Garrett T3/T4
25G/20G/24V/18G etc is the compressor wheel
Fark it...i am selling all my mitsu fluff and going KKK K27s etc. Info on them is even more confusing :whistling:
Do you want mine?
cbf going to get it, but iirc it is a 7200 11:11 with a #6 rear housing with a porsche flange pattern
LOL
ok so can someone confirm this if this is the correct TD06SL2-20G that i've bought *which is same as jez & artz*?
i hope its not the wrong one Lol
http://www.ebay.com.au/itm/280776600350?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com....984.m1423.l2649
LOL its the right one man, good work.
Johnny B - go with tried and true man. In theory the water cooled one should work just as well but run cooler, but it comes with a smaller compressor cover and thus could be a lucky dip in terms of results. The T67 is a known performer, no guess work!
Stock manifold yes, don't understand why people r using the aftermaket manifolds for the TD06 turbos unless its for a T67 which fouls the engine cos its too big. What gate r u using dori, Tial?? Are you plumbing it off the turbo housing? Keep us posted....:thumbsup:
modded the stock manifold to suit 44mm v-band ext gate, running either a tial mvr or turbosmart hyper gate
tbh, i think after all the costs add up, it will be about the same price if not cheaper than a HG unit fitted.
turbo with lines (can sell for $$ if not needed) $740
gate $300
modded manifold $220
dump + screamer $150
intake $150
= $1560~ (say $1650 for gaskets/bolts/nuts/studs etc)
HG turbo on its own is $1500 + delivery + custom intake + either use OEM lines (needs massaging to fit) or need braided stuff ($$), fk around with the dump/front pipe issue melting the aircon hose.
Ur right, thats what I figured out - Putting together THIS stuff is about the same or cheaper than the HG ss stuff, the HG turbo on its own is $1500 + GST = $1650 = ouch, I just burnt a large hole in my pocket for a turbo only...
Whereas with this one, if ur not happy with the turbo, u can always get another spec turbo or parts (diff wheels / housing etc, as kando sell a wide range of this stuff for cheap) for approx $700 and ur sailing ...!
What do u guys think??
And where did u get the 44mm Tial for $300 - the cheapest on eGay is $365 + delivery = approx $400
People car do things for all different costs, some cheaper some end up paying more.
I dare say since these setups work so well you would be best to spend the few extra dollars and making the setup 100%. Using some high temp sheathing on lines, good quality bends and reducers/flanges studs etc so you dont blow out gaskets etc or warp with temp.
A gate for $300? I paid about $500 for my Turbosmart. I paid more then $150 in just flanges, studs, gaskets and elbows + reducer. So not saying anyone was wrong but we all often pay different prices for things and I know i couldnt do my setup with external gate that cheaply
Tial MVR is the go Dori, proven performer. Also not sure where to get it under $400 or I would LOL
Ron your comments are all well and good, but please make sure you have a firm understanding of the setup you are describing and how it works before you attempt to undertake such a move.
Make sure you have your labour aspect of things well sorted and know the implications of a screamer (if you opt to go that way) or how standout your setup will be to NSW highway patrol.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
