ARTZ, you make me sad.
i would've purchase your whole setup if only you put it up earlier. maybe convince handaldo to buy it all off you lol
hope it all goes well for you mate.
Hand... Aldo? Is that me?
I believe that joey was running 320rwkw with Nismo 550's on E85 with his 2835pros
Even if they don't cut it, run as much boost as you can to get to about 95% duty cycle :thumbsup:
How is that good advice?
I still dont see how 550's could come close to flowing enough, even at stupid rail pressures. Like I mentioned Artz, chase up a Neo rail and get some ev14's shoehorned in there.
aahhhhhhhhh........ok f**k it.....
I'll finish what I started, on the cheap..then if I'm still sick of it, I will sell it...
sale on hold till further notice... :whistling:
one Q...will 550 nismos cut it...???
I know most are running the 740s but how much headroom is there??
why dont you just do what i did and pay $300 to get the stock side feeds hi-flowed?? mine are 90% @ 340kw...
Or maybe you should buy mine and i will get some ID1000cc with some valve springs then wind up the boost!
wrong person, i mean to say rondofj :P
tschh..Im still off the road for another 2+ months, well yesterday I fitted in my new JJR dump/front and new O2 sensor and cannot be happier with the instant response and pull factor..still some way to go..new injectors and afm..before I get the Kando or HG..ya ya I know my new dump will need to be modified if I go Kando..:blink:
yeah im keen n the ev14ks now actually, the smallest of them, need to find a neo rail on the cheap though to make it viable....
http://www.bosch-mot...alves/EV_14.pdf
why not just get these and plug connectors from bursons..
http://www.ebay.com/itm/Siemens-Deka-60lb-EV1-SHORT-High-Imp-Fuel-Injectors-6-/390213457860?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5ada88d7c4
i remember reading on the xr6 turbo forums that the siemens injectors require some different tuning paramaters to most factory injectors. my memory says injector pulse width?? whatever it was, once the parameters are set correctly they idle very well.
ARTZ, finish what you started.
Once you sell and the new commitment comes along you wont be seeing any play money again for a while... 1K is a couple of weeks overtime, suck it up and keep at it!
hahaha....I know you could do it too.. :rofl:
yeah Scotty to the rescue...I went to hire a trailer mate, was 120$ + stuffin around, So i rang my towie, he will drop it and pick it up for 100$...legend!!!
those deka injectors are dirt cheap, can get a blank fuel rail for about 30-40$ yeah..wonder if we could make the stock reg fit..
I was talking to another bloke today reckons they are fine as long as you get a dampner in the fuel line.. :unsure:
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
