Everyone loves the sl2 cause of intrenet yabba..there is no real results yet so few of us decided to try it, now everyone is jumping on the bandwagon before we has results...
Sl2 will probaly only do around 260_280. On pulp..thats all we ever expected, and all the stock manifold can really deal with comfortably...what, you expected more??
Yeh its crazy people seem to think these td06 things are a new thing...
I was trawling yahoo japan auctions for months before this thread looking for a genuine Trust SL2 or T67 rb25 kit then along came Simon pushing kando the great! :)
Edited by battery
Keeping true with our bang for buck theme here a very interesting comment was made in the following thread:
Ebay steam pipe maniofold thread
Noel is a high end user and clearly approves of the item, the price is also great. This could be a good combo with a kando, again making the T67 option even cheaper.
I may look into getting one for my SR :thumbsup:
Sean from Allstar who tunes my car grabbed one of them for a slapper/thrasher build. The quality and welding was ok but the design of the manifold leaves a lot to be desired. The angles of the runners merging and wastegate exit were average at best...
He never ended up using it because he sold the car (I should ask him where it ended up) and if it was ok but he wasn't too keen on using it.
It's not going to be close to a decent manifold but if it does the jobs reasonably then they are a bargain :)
Edited by SimonR32
i remember seeing a picture somewhere of the merge collectors, and they were of the same quality/design as of the cheap chinese s/s high mount manifolds.
That's what I was trying to get at, they do have the advantage over the stainless that they should be more sturdy and not crack/break
I guess the idea is for ease of fitment and to uncap the stock manifold.
For me I would happily whack a kando on a china SS manifold if I knew it was not going to crack.. these kind of fill the void.
By no means do I suggest them as a 6b replacement :) but hey im sure they work about as good as a china SS without the cracktastic outcomes.
I figure if you are going aftermarket manifold you want it to be an improvement over stock so why get some shitty design with bad angles?
they will work, but it could work better
$300~ebay job Vs $1100 6boost
if it does the job, ill be happy to spend $300 as it will definitely be an improvement over the stocker.
Oh god the war begins again stock vs aftermarket manifolds. Iv bought a eBay manifold ONCE and I ended up cutting it up and turned it into a screemer pipe and it actually worked very well haha.
LOL you mean you made the whole manifold into a screamer pipe or you added a screamer on?
The first one would be funnier lol!!
how do you know that?
did you not read the thread ?
ill post it here in case you missed it where fineline fitted one to his car, i don't see a stock manifold hitting 500hp?
I'm using one of these manifolds on the gtr. It came in a package deal from an expatriot kiwi with a new turbo.
My first thoughts were the same as yours, doubt as to the quality, I showed it to a couple of mates in the welding and fab game and they gave it the thumbs up so we went ahead and bolted it on.
Its done a few k now and is about the best bang for buck mod out there. zero problems, perfect fit, no restrictions when we tuned it.
We took the tune out to 500 whp before turning it back to a safe 450 whp for safety (stock bottom end)
I wouldnt hesitate to buy another if I needed it based solely on my experience with the current one.
theres always a cheap way and an expensive way to go about things.
like i said, it may work ok for $300 but for $1100 item, it will work better.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
