i've searched and everyone says they're a waste of $$ on a RB25, with zero gains
Really? OK, I stand corrected. Everything I have ever read suggested that the RB26 and RB25 were the most responsive to cam gears, (a friend played with custom inlet cam gear on a NEO and got nothing from it...but an adjustable cam gear worked well on his exhaust side)...and RB20s respond well, but not as well as its bigger cc cousins.
I have read that cam gears were a waste of time and money if you were running Poncams. But...can't say I have paid too much attention to it the last 5 years...it used to be a golden rule
I quickly discovered a page or so back he hates one of the best engine makers in the world - based on that lot I'd not really expect him to have the kind of appreciation or understanding of optimising engine efficiency needed to treat as an authority on the topic.
i think it was Trent who mentioned something about cams being not worth their $$ on a RB25.
got a dyno sheet of this? if there is proof of gains i will get an exh cam gear.
Lithium, you referring to me about my honda post last page?
Cam gears , not cams! I have not heard of too many RB25s not responding well to cam gears on std cams.
As for dyno sheets? Hell man, we are talking around 2004-2005 when he made a custom inlet cam gear that could be adjusted as part of all his trial and error. It was all for 0 anyway as the setup worked best set at 0 and the exhaust side retarded a little using his off the shelf HKS exhaust cam gear
It all depends on the set up some rb engine greatly benefit from cam gears some not so much personally I think it would be a decent investment cos lets face it if your chasing power you have wasted money on worse things I know I have
Gone through the last 40 or so pages. Am I imagining things or are not many people running the TD06H-25G? I know heaps are running the 20G.
I am looking at this turbo http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-Inlet-TD06H-25G-T3-V-Band-10cm-AR73-500P-/270913941567?pt=AU_Car_Parts_Accessories&hash=item3f13bab03f
Im not a guru on turbos so I thought I would ask here. I want great response since ill be doing track days, am I looking at the right turbo? Chasing around 300ish kw.
I also noticed the two types, water cooled and oil cooled, which is better?
If you were looking for a easy 350KW on 98 would it be better to go as TD06SH 25G 12cm or T67 25G 12cm?
Whats the power difference between the TD06SH and T67?
I know the TD06SH has the 58.8 and 67 turbine wheels but would it push it enough to make it worth the lag?
sorry, it was a typo, i meant cam gears. i'm still against them until i see proof provide decent gains.
it will not be a decent investment after the $$ you spend for your tuner to tinker with them and to set them up especially after all the work and only to find maybe 1-2kw gain (if your lucky)? Lol
+1 i didnt notice any gain from my cam gear install
:yes:
You answer your own question the h has a bigger turbine wheel I had the td06h-20g on my 20 and was seeing full boost at 4200 18psi so it's only a few rpm if you want bigger numbers
:yes:
Haha depends if your tuner try's everything and not just turn up the boost. I don't think it wound be worth it on your set up because the turbo is already working very well. From what iv heard you can get more mid range and bring the turbo on faster that why I thought it would be worth it not so much power out put.
i've still yet to see a dyno sheet where it provides a gain in response in the mid range.
i've seen some results with cams installed but not with just exh cam gear adjustment only.
feel free to prove me wrong, i am skeptical until i see evidence that it works.
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
