See if he offers money back gaurentee's?
I do. If some one isnt satisfied i will refund all tuning money and load the tune back in they came with. Hopefully it never happens.
I will try help u out as much as i can for price wise buddy.
Let me know.
Yeah, i will speak to him if there is any further delays and ask for money back, and he will reload the old tune and ill just drop it off @ jez's
lolololol
Still battling with the tune >_< Sounds like JEZ is the way to go here... Hopefully your tuner can be reasonable after everything you have been through :glare:
How come? You wanna go for a schpinn?
You can call ARTZ, his is running and making an awesome 267kw at only 1 bar and with a failed clutch :)
pretty sure he was referring to Jez so he can use him for tuning lol
I know, and i hope so too!
JEM was on the cards early last year but he couldn't squeeze me in.
hopefully can get it sorted out asap. i miss my car :(
Sorry that was directed at JEZ, people got their posts in before mine. I probably would have gotten JEZ to tune my SS1PU if he were in Melbourne, but my car is in very good hands at Racepace so :)
As for Artz, I plan on dragging the mofo if my SS1PU does what it's supposed to ;)
JEM are the gurus when it comes to Haltech :thumbsup: I cant wait to get my car tuned.... I MISS my car after 2 years lol
Look forward to seeing the finished result on your beast :cheers:
New haltech and vipec/link software is awesome and very similar. Same layout which makes things easier.
Race wars
Kando vs Hypergear.
Gonna be a good race. I wanna see results for a rolling 3rd
Gear start from 2000rpm. Or 4th if ur on a race track. Curious to see who comes on boost 1st an wins up top
Haha Im getting more keen on the Kando vs Hypergear result than Dori's results lol..
Don't forget, the abilities of the drivers count big time as well.. So maybe do a driver swap and see if the results can be replicated..?
How can the driver abilities count? Goes like this-
Pull up at lights look at each other,
Kando driver says, "whts the retail on one of those",
"More than u can afford Pal, hypergear" rev car and make dose.
Then cruise up to race track Put in 4th gear both at same speed around 2000rpm. Look at each other, nod then foot flat
How can the driver abilities count? cruise up to race track Put in 4th gear both at same speed around 2000rpm. Look at each other, nod then foot flat
:pwned::rofl2:
I'll take a stab in the dark that, in a rolling scenario from low rpm (2000) my car should pull ahead, given it's the more "streetable" turbo and gets on boost from about 3000 onwards...until around 4000, where Artz would come on and start to reel me in / eventually overtake. From there who knows...probably come down to max power and turbo efficiency in the top end. The Kando might well take it there if Artz can get his slipping clutch sorted.
Would be interesting to test a couple of different scenarios...the rolling from 2000rpm to test lag, and a rolling from 4000rpm where both turbos should be well on song, to test their response (?).
We can swap cars just to get a feel for each turbo, compare based on subjective opinion...but the only fair objective competition would be a rolling drag IMO, taking driver skill out of it.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
