Yeah Unique automotive in villawood, he tuned my friends turbo excel, well tried to atleast. They told him to tune it on no more then 10psi, but he ended up incorrectly setting the boost controller to 18psi. Was also overheated on the dyno 3 times.
Lol maybe that is why they are so 'Unique'.
Sounds like another workshop to steer clear of.... Good tuners and good workshops are becoming a bit of a rarity these days.... I had a bad experience with a local workshop recently and will never take my car there, nor will i let my mates take their cars there again... Word of mouth goes a long way! :dry:
On the flipside, word of mouth also goes a long way with GOOD tuners and workshops
I would think taking that centre bit out of the manifold is a bad idea. because the turbo isn't centered you have 4 cylinders of pressure on one side pushing against 2 from the other makes for uneven flow pattern. If it turns out to be the culprit piss it off and get a hybrid topmoumt I'm dying to see how well it would work :P
Failing that my guess is you have fuel delivery issues, but it's just a guess..
Dori34 i doubt it is your manifold.I got mine tuned last weekend and was worried the manifold was going to cause turbulence problems. My whole top half of the splitter is gone. Silly me put the 20psi spring combo in my gate assuming it might just run under the target pressure(so i can use boost controller to up the pressure 1-2 psi and ramp boost up abit quicker) but ended up going to 22psi in the top end. the least power it could make was 300atw with very minimal timing and fat AFRs. That is on caltex eflex though. going to see Trent this w.e for a touch up and il ask for a dyno print out and il post them up.
Your not getting a bad name. The quality of your work has not been mentioned at all.
Putting a gate on the stock manifold wasn't guaranteed to work, its nobody's fault if it didn't. It doesn't matter how well you did the job, it matters if putting a hole in the collector of a divided manifold and a gate within a few inches of it will create turbulence.
See what happens anyway.
yeah gate on manifold should be fine, it was just removing the splitter I was unsure on,,but as it turns out its still there anyway...so my point was proven invalid already..
secretly I was just trying to talk him into the hybrid topmount though cause I want to see how it goes..
OMG am I seeing ghosts or what- just how many doris do we have here?? One talkin to the other.. Confused:S
TBH, i wouldn't be suprised after the last issue with my "boost issue" which was just the EBC set incorrectly.
the boost plot is only for the 1bar run, but from what i saw, the 1.2 and 1.4 bar runs was just flat line like the 1bar, no issues there.
OH NOOOO
Hey dori33, what's done to your car and any Dyno sheets? I wanna see where the restriction is how it looks ok a Dyno if your maxing out a Mani.
Guys, please don't doubt the manifold, it's been done before and they've have made 280-300rwkw on this set manifold setup, Blake has done a good job. he's done a lot of work for me and I appreciate all his help
Thank to Jez you legend, looks like another silly mistake done by my tuner.
I think I'm gonns book it in with you earlier cause I can't wait any longer. Speak to you soon mate.
im just having a look to see if the haltech works off kpa absolute or kpa.
ill send you the tune back with the overboost raised, let me know if it still cuts out, but obviously dont go thrashing it as the tune isnt finished for high boost
Not so much a bad name but I loose work over people saying the manifold don't work it does work and it's proven as jez just stated boost cut wasn't changed for high boost. If the manifold wasn't working it would be spiking seems every time dori has a boost issue the finger gets pointed at the manifold and it effects my clients Thinking my product is shit
hey rondofj can u try one on a hybrid manifold, looks like doris car is sorted damnit >_<
I mean YAY!!! :banana:
At the mo im just about to come out of a 6 month hibernation in a weeks time, but hopeful of dori's results too as thats whats Im intending to do.. :)
On an unrelated note Jez, what is the difference between the PS1000 and PS2000 based on a setup like Dori's and like mine? (Bit of a Noob question i know...)
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
