It's alright, I'll be doing the drag before E-flex so that it's fair :P
But yeah...E-flex is clearly the way to go for street cars wanting big power. Imagine ~300rwkw with response not that far from stock!
Oh..i guess i should leave the nitrous at home then :(
When I get my frikken car back :/
Have to get it out of the way soonish because I'll be switching to E-flex after a month or so of driving on 98. Time to see what an ethanol powered SS1PU can do :thumbsup:
I went past racepace yesterday, they look busy..pretty sure I saw your car buried in there somewhere though
oh so you're switching to the magic juice too?!! dammit >_<
You know you wanna!! As soon as my financials are sorted ill be getting tuned on it AND the nearest servo is about 25mins away, so dont use distance as an excuse :P
You think that's bad, I'm pretty sure my nearest servo is also your nearest servo :P
Who wants to help me take down the WA government? Anyone?
have u got his 98 graph somewhere that you can post up Scott?
I actually found it before lunch, wish you had asked prior lol. Its roughly the page 15 area of his GTX thread.
He made 288 peak, about the same power at 3000rpm and about 20kw less at 4000rpm..
So once your VCT is fixed, you should easily make more at the 3000 mark, and open the gap further at the 4000 mark. Who knows... Maybe the surge cover will also help you clear more up top too.
Haha OK, YOU have a legit excuse :P
But you are all setup for it so go get the WA government sorted :domokun:
That would be pretty surprising...
Not to me. By my understanding, compressor speed could potentially be hindered by the surge and not recovering in full by peak power.
So if the surge slowed shaft speed theres nothing to say that it wont let it follow through a little further over the whole graph once its fixed.
The above is assuming its not out of puff at its 280kw point (the graph appears to level out but that could be in Jez pulling timing before the redline). Just shift the 'after dip' curve back to where the dip starts and there is this 1000rpm gap up top.. thats 1000rpm of power making potential IMHO.
Hey Dori, do you have any pics of the engine bay esp where the wastegate is connected = all the piping / screamer / intake etc?? Would help others I'm sure and the experienced members might pick up a thing or two with suggestions..:cool:
GTScoTT - Easy way to prove you theory would be to pull the wastegate hose off and do a dyno run or a 3rd gear pull, if it doesn't free boost then you're quite right - my money is however on their being no issue with shaft speed, and that the wastegate is earning its cash keeping shaft speed down by those rpm... and I'm pretty sure people mentioned wastegate noise earlier on, which would imply that is definitely the case.
No. AFAIK its only surging on spool up at lower RPM. So that would mean the WG is still controlling boost once the motor starts to open up. BUT, I still believe that could impact it up top.
Remember the silly RB has a threshold where it opens up around the 4000 mark, and these 20g's are making boost at the 3500 mark.
That being said, there is probably MOAR to be had if we can work out how to make the thing swallow more air before its natural threshold (Peak torque at lower RPM).
I know that, but as soon as the surge goes it will be spooling as per normal - as will be evidenced by the fact that the wastegate is open. If the wastegate needs to open, the shaft speed is MORE than it needs to be... simple as that.
Thats what VCT is there for, make more torque sub 5000rpm and will also make surge less likely by eating more of the air from the 20G. Should improve spool slightly too, more VE = more gas flow = more turbine driving.
here's a nice one of the manifold/wastegate pipe glowing
but i put up proper pics a few pages back, go back & look for it, would've been around Jan-Feb sometime.
I understand your reasoning, but I also understand my own :ph34r:..
As usual we each have convincing conflicting arguments. Lol. The way I see it, we could both be correct. To put it out there I am pitching my theory as a 'possibility', not a fact. lol
Thanks dude, that looks like a nice little oven there though..
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
