lol my bad probably should of checked from page 1 I started reading backwards for 20 pages or so.
lol nws, atleast you can cop the flack.
Page 185 has Simons most recent result, with a direct comparison T67 vs 3076R.. the only difference being the ethanol content of their fuel (but I doubt you need more than the Jew mix simon runs).
You asked your question 2 pages later, within the quoted 20 :P
Yeah saw that just brain was lazy and didnt click that the boost was in kpa instead of psi so wasnt making sense until I realised this and converted it lol.
WHAT!!!!!!!!!!!!!!!!!!!! mines anti surge...ive never seen a garrett loose power from anti surge.. :unsure:
TD06 25G anti surge 50mm wastegate. better make me my 300kw on e85...damn kando bastards!
Edited by 51NNA
Well on Dori's car which is a head fck as it has some weird issue's.
It was laggier, and less top end. Wanted to ping at 240kw where as last time it was making 280kw on the edge. Lost 30 kw at 100kph also. Had the exact same surge issue as the non anti surge housing which we think is the profec playing silly buggers with us.
It wasnt until we went for a run on the road that i noticed it hitting the boost warning. Weird thing is the boost warning is set at 26psi and profec isoinly reading 20. So i turned warning up to 33psi and it didnt surge once on the road after that.
We couldnt find a bleed valve lying around as i lent my last one out to another customer during the week.
Only things changed since last tune where anti surge housing and the exhaust leak was fixed (other end of the plumb back pipe for external gate wasnt sealing) but is running screamer
well thats a mystery, I cant say ive ran Kando anti surges before but I have run alot of garrett anti's and the most ive seen is a 1-2kw loss, ill pull my cover off tomorrow and compare it to a garrett thats laying around.
Not the only difference, Simon's was running a bit more boost too if I remember rightly?
I'm wondering if I will have the same issues with mine then. I got a TD06H 25G with 3" anti surge housing. I',m wondering if I should have gone 4" from what your saying
you should be fine bro, that housing is an actual TD07 MHI spec item
the housing Jez and Dori are having issues with is a 'drilled' TD06 3" cover. The Trust style one that never came with drill holes in it normally lol
its a shame it didnt work though :(
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
