Hey Scott this aint the truck turbo thats staying on it, I only fitted the truck GT3782 for giggles to see if the bonnet would close and kill my curiosity. This is a Kando TD06H-25G with a billit compressor with TD07 comp cover and 12cm rear but like you, I'm also quite confident that it will flow more than enough through a 3" cover
Sorry if I came across wrong.
That 3" TD07 housing is a truck one im pretty sure. I was just trying to make a point that you dont have the same 3" housing dori tried. Dori's one was the standard .60 trust style 3" thingy that has had surge holes drilled into it. Yours is an actual surge ported housing (not a modified one).
Most trucks use surge ported housings, and its not a typical trust housing which is what makes me confident its off a truck.
All in all im sure yours will work mate, no need to worry at this stage.
Did another track night last night and turbo still going strong, ran 1.4bar and 515hp all night and didn't miss a beat :)
How many km's you put on it in the last 18 months Simon? It's def proven its reliability
Id like to know if Simons has cracks on the turbine.
Twice as curious to see if the 20g I buy comes with complimentary cracks lol. Logic says no, because the td06 and t67 are a different shaft and therefore cast (shaft and wheel are one item).
Viva la cheap Chinese rubbish.
You would think it would have let go by now if it did
Cheap but not so nasty
Edited by t_revz
I'd probably say around 5000km's. They would be fairly hard km's as most would be at the track, drags, powercruise motorkhanas etc. I have a work car that I drive most of the time.
I don't think that the cracks 'battery' has would cause the wheel to fail, they are not at a stress point (as far as I can tell). For all I know mine has been cracked the whole time as well
Sorry if I came across wrong. That 3" TD07 housing is a truck one im pretty sure. I was just trying to make a point that you dont have the same 3" housing dori tried. Dori's one was the standard .60 trust style 3" thingy that has had surge holes drilled into it. Yours is an actual surge ported housing (not a modified one). Most trucks use surge ported housings, and its not a typical trust housing which is what makes me confident its off a truck. All in all im sure yours will work mate, no need to worry at this stage.
Ahhh true that, and yeah your probably right about the housings now that I think of it.
Had my l2 20g off last weekend to weld an elbow to the outlet, mine didnt seem to have the cracks in the exh wheel like the 67s. Turbo hasnt done too much work, but it still looks and feels brand new with the housings off. Couldn't be happier (well i could if the car was still registered and i wasnt goin to court)
why no burnouts :(
I want burnouts damnit....
We got told just because there was a chicane doesn't mean it's a excuse to do burnouts, luckily for me I just put my foot down and it layed lines. Not my fault :)
Edited by SimonR32
just brought a Kinugawa Turbocharger 4" Anti-Surge T67-25G T3 10 cm V-Band. waiting for it to get here. just need clutch, 6boost, fuel system, gate, tune and plenum before it gets fitted... then let the fun begin! :woot::cheers:
Edited by boooooooooooooooooooostin
Just need 10 grand before I fit my $800 turbo.
Just kidding mate haha, should be a weapon! Maybe avoid the anti surge... Dori34 proved it wasnt so effective.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
