Won't fit on his manifold though.
I'd go the TD06 and enjoy the response if it's a street car. I love the way my T67 brutally ramps onto boost, but if I was using it daily the lag would horn me.
Noob alert!
My 10cm rear might just rock up on Monday, and I'm tempted to fit it up over xmas. Am I right to think it's held on by a clamp? I've never pulled a turbo apart before. If it's fairly easy to do I'll definately give it a crack.
Cheers guys!
edit: Just realised I can look at my other Kando to see how it comes apart *facepalm*
Edited by Run-It-Hard
is it?
boost doesnt kill engines...
mercury motorsports run 40psi thro their stock rb26 lol
Heat(through high boost) kills engines by detonation right? I am sadly only running 18psi on my R34 RB25det due to intake temps approaching 50deg C, was hoping for 22psi :(. Precision 5558 0.63 making 286rwkw
WMI :)
the t67 made 294rwkw on 18psi
Which means the 5558 is not doing so bad 286rwkw @18psi compared to the T67 [email protected] as the T67 is bigger; m thinking of changing my cooler piping AWAY from fan and radiator to make a sort of a rounded 'V' piping instead of the typical rectangular 'C' across the engine to keep temps cooler and allow me to run at least 20psi, heck even 20psi is too low for me.. Do you guys reckon the V piping will improve things (cooling) a bit??
And sorry for spamming the Kando thread aargghh
Edited by rondofj
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
