sounds interesting, although be expensive compared to one big china single, people more commonly use
cheers
darren
yeah i hate singles on 8's im a symmetry kinda guy :P would be happy to pay ten times the amount just to have twins... plus the results are better.
Bit delayed though now, the stupid dry sump setup has gone missing.... DHL are trying to track it down
that looks to be a highflow with stock housings, prepared by sir kando himself. looks to be a new release, nobody has one yet.
i would be interested to see how that performs against the staple GCG or hypergear. Price wise its in line with the hypergear but seems to have very different specs.
A T3 stage 3 rear wheel with a 20G sized compressor. The T3 stage 3 is similar in trim to the TD06SL2 turbine but is larger in inducer diameter.
Would be interested to see the results.
Interesting. The stage 3 Sierra wheel was that I've used for high flowing 5 years ago, same as the old school TR44xx turbos. I've also bought some of those bolton turbine castings, They are a modified KKR430 .58 turbine housing. Will be building a new billet bolton turbocharger with it soon and making sure it has the best power/response curve.
it would be good to see you use some smaller trim turbines Stao, your current range all have larger trims than their garrett equivilent which some of them are already on the big side (GT30 v G3 wheel)
Dave it says 15psi actuator and 2.2 bar limit lol
Would you say it's smaller or larger than your pu highflow
So its a sierra rear wheel, usually they use the 58mm V-trim or H -trim comp wheel for those, not a 52mm. Been the staple
diet of hi-flows since jesus was around..still work, with a 58mm comp wheel they will push a barge ass R33 Rb25 to 120mph traps, and
vl manual turbos faster again.
cheers
darren
Edited by jet_r31
Whoa that's a lot of speed out of a liner. I wonder why kando went for the little comp wheel?
to my understanding these old tech wheels are still I'm circulation with some of the biggest name turbo builders out there.
Might talk to a mate and see if he wants to try one of these
oh yes...i drank a bit yesterday...
:blush:
cheers
darren
my car is not a barge ass :angry:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
