It's lighter than stock, I think around 1200kg. I'd love to know what the turbo could do "all in" but it's not really an option with the current injectors and MAP sensor, and to be fair I'd say the head gasket/head studs would probably be worth upgrading before doing something like that too.
Still not too bad for a basic setup that has that wide a delivery, I reckon.
This is the dyno plot for ~16-17psi, if you hadn't seen it:
just got my TD05-18g last week...agreed, EXTREMELY quick delivery, was only 3 business days (ordered late Tues night, here first thing Mon morning). Missing the bullet nut I had ordered but they shipped that out quick too and got it today. Trying to fit over the weekend and found a couple of issues.
Longer studs I bought didn't fit as they were m10x1.25, and manifold end being m10x1.5. I did read that in one other post but most other ppl said m10x1.25....wasn't entirely unexpected anyway.
Oil drainpipe it came with is useless, 17mm not 19mm, and way too short to reach. Drilled new holes in flange of OEM drainpipe and used that.
Waterlines were biggest issue. I want to have water and oilcooled, not just oil, but the banjo bolts won't even come close to fitting in the top ports and allowing the hose to screw on. Unless they're pointed straight up in the air which is just ridiculous
have read that both of these ports on both sides are for water, and ok to use either the top or bottom, but the return should be the upper port, is that right?
Andy did you go with an internal gated housing? Interested to hear how this thing performs and if boost control is ok.
I don't rate the hoses and fittings that come with the Kando gear, very little that is useable and anywhere near fits.
I think porting the internal gate Kando turbos is well worth it, it's not that hard at the time and much less of a PITA of the potential situation of discovering you have boost creep, and need to pull the turbo off again.
with vct turned off its dog shit under 5k, with vct turned on its really good still, full noise around 4500rpm
3rd gear roll on from 40kmph up to 4000rpm I reach .4bar with vct off.
3rd gear roll on from 40kmph up to 4000rpm I reach 1bar with vct on.
cant I post link to youtube vid on here?
Edited by methz
yeah porting out the watersgate might be needed, will see. To me more of a concern was the chunk that sticks out into the exhaust flow, from where the wastegate port is drilled into the housing.
Bit of work with a carbide burr and the flow is much smoother. The entry was also a bit smaller than T3 size, so ported out to match the manifold rather than leave a lip at entry (looks more even in real-life lol, though looks a bit wavy in pic)post-78602-0-31201300-1392696221_thumb.jpg
Got the opportunity for a power run for the 16G on 20psi, so took it and were pretty impressed with the result - 20psi was road tuned and is the limit of the injectors so not necessarily an indicator of full potential but still pretty sweet. 297kw @ hubs, 20psi hit by 3500rpm:
Never using another kinugawa again had 3 t67s all ex gate 10cm rear on 3 different r33s fail within 2 months (suspect was didn't have 360 thrust bearings) after sending then back under warranty costing $164 each one they are warranting them even tho they are 2 months old and are wanted 350 per turbo to have them rebuilt. What a crock. This is why I should of suggested these turbos over hypergears you cannot compare compare the level of customer service and satisfaction you get from Tao not to mention the countless dollars out of pocket
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
