after a few cans myself jenna and a few mates decided to have a crack at a victoria track day party
plan is sometime in july take a week( maybe more) off work and drive south
winton
philip island
a hill climb if possible ( haunted hills)
maybe some skid pan day down in mexican land
and maybe sandown if we are feeling hard core
probably do wakefield on the way back and marulan just for shits and giggles
anyway im puting the feelers out now as we all know sinking piss with more people is more fun that with just a two car convoy
pete
note: i have not thought this through any more that what i typed above
https://www.sau.com.au/forums/topic/348205-vic-track-day-tour/
  • 1 month later...
I'll Leave my liver and kidneys at home for this one................
He he my first post for god knows how long on SAU OH YEAH!
Racing + Beer = Nuddy Run thru random country town.
So you better notch me up too Neil.
Edited by Easto
I remember you!
Is the black pearl still red? does it run?
Yes it's still red, if i ever manage to acquire a set of flares she'll look a little better.
It looks a bit beaten after i tried to make my own flares which was a massive fail!
She still runs too i've been to the track a couple of times lately and should be out on the 4th with some brakes that actually release when you take your foot off the pedal. Ha
Whats been happening during my lull???
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
