well, im effed. i checked the informeter and my car hits 94% injector duty cycle :(
so am i. lol hence the upgrade.
tell me if im stupid, but the new pump shouldnt affect my economy shouldnt it. i seem to be getting alot more out of this tank n im not hwy driving, maybe our stock one flows better
higher pressure = better fuel atomisation = more power with less fuel
OK massive thanks to Craig and Andy for their assistance (Craig did most of the work lol) with installing coilovers, sway bars, underbody braces and brake pads, rotors and braided brake lines.
car is a litle different to drive now :)
its wet so i cant really test it, and there is a small knock coming from the front and a rattle from the rear, but i suspect Andy didnt put my jack back in the boot correctly :P
Yes, I did very little work indeed. Craig is a legend.
AS for the jack, I even strapped her in... lol
The car looks fully sick BRO and I am sure in the dry it will be a sweet riding beast.
ill connect my iphone and post the pic of its lownezz :P
EDIT: pic shows the BCs "out of the box" height. the rear needs lowering a little, and the front needs raising.
its gonna looks great with the nismo rims.
Edited by zei20l
What size wheels will you be going for? And by nismo i assume you mean LMGT4's?
should look awesome with the Nismo's!!
Car ride height definitely need's to go up about 40mm in the front and down about 60mm in the rear. That clunk you were talking about in the front...is it a metal clunk or could it just be hitting the bumpstops? The rear could be the exhaust just touching the swaybar.....wasn't much room there!
We should line up a day this week after everything settles to go over everything again.
I presume the brakes are good?
Edited by Jetwreck
Looks great man! i think the ARX shoes sit nicely under it! the Nismo's should look sweet!
If you guys do hook up, do you mind if I come along and have a stickybeek and learn a thing or two. I have tones of questions?
but nothing should change seeing as i havnt changed the injectors or fuel pres reg.
the stock fuel pump may have been running out of legs on boost and may not have been keeping up with the injectors
so you get low pressure in the fuel rain and poor atomisation by the injectors
you may also want to do the 14v fuel pump rewire
check out the diy section, it applies to most cars
Sounds like it could happen.
I'll speak to some of the m35 guys n see what they say about it, as far as I know m35's dont have the voltage problem other people seem to have with fuel pumps.
Appreciate the advice!
Edited by AaronNM35
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
