well today i got the dump exhaust off..to fix the exhaust gasket leak.exhaust.. turns out there was maybe 1mm of the flange that WASNT leaking. When I pulled it off to fix it, it looks like the exhaust shop that did the exhaust did a dodgy, and shrunk the 3" to about 2.5" and put the stock flange back on (never taking it there again). Scotty the f**kn legend cut some of the exhaust off put it back to 3" with a new flange.. fixed.
Ok so made up a new gasket from Gasket material, with some gasket/exhaust seal. n put it back together..
it set.
Started the car.. i'de safely say about 50% of the turbo whine went away...sounds normal now..
still gonna take it to the turbo shop on monday to let him have a listen first..
once this all finished. i made some great souvlaki's and now im full and scotts so full he cant breathe!. goodnight Stagea owners.!
Glad to help.
You can cook those spicy souvos anytime mate, yum. :cheers: (sorry I know, you don't drink) :)
  • Like 1
I just get a black spray can and paint the i/c (just the front face) and piping black.
Isn't the stealth kit more expensive? Did they charge you the extra for it?
If not, I'd be spraying it yourself. Just use a satin finish.
did a service with Motul Chrono 300V + Greddy oil filter last weekend, i'm amazed at how smooth the car runs.
stewart warner boost gauge in, and reinstalled the foglights.
thinking about spraying the roof section between the rails gloss black - think it will look nice with the twin sunroofs tinted out. thoughts?
yes Ive always wanted a black roof between the rails, down the front pillars and over the bonnet
dayz S1 snow white.
and yeah the stageas Love the Motul 300v and Royal Purple.
anyone seen the 14point7.com widebands?
$100 for the controller, $50 for the o2 sensor
diy (basic soldering)
will probably be my next purchase (eventually)
also, mine is running pretty averagely, bogs down on cold start, feels very doughy, hesitating a bit :-/
i have a receipt for iridiums fitted about 20,000kms ago
i think i found it tho, someone has previously cut and replaced some of the wire going to the afm but only crimped it
so i soldered some new wire in and now it seems good :)
solder adds resistance to the wire, hence the crimp :)
Also on thin gauge wire, if too much heat is used, soldering can remove the annealing (which makes the wire malleable) from the copper and make the strands more susceptible to fatigue breakage.:thumbsup:
Edited by Daleo
Yep, just some Jaycar 5awg wire and some electrical ring connectors!
what do you ground?
as to the soldering, slightly higher resistance is better that random connections
i'll measure the resistance across it later
Recieved a box today containing my R33 calipers!
Got all the lines, shims and clips, and as a bonus what appear to be a virtually brand new set of brake pads :thumbsup:
Now for some offset brackets & bigger rotors...
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
