Yes, it will last 10,000kms for sure
5000km changes? Bullshit.
10,000km with a Group V oil is no problem... unless you are tracking it.
yes well from the troubles i been having lately, im not being a penny pincher and am doing it every 5000km.
i agree with 10k services. 5000km is overkill for a street driven car
really?
why are all the performance shops saying every 5-7000kms a service should be done especially being a turbo charged vehicle?
fact that im going for a tune on wednesday change anything? or ...
because people pay over $200 per oil change at a performance shop.
do an oil change before the tune
no but this is a performance shop knowing that I'dd do it myself..
yeh theres no oil in the car.. once the turbo goes on im doing a flush, then putting some new oil in, then driving that up to get some Sougi 6000 or whatever it is.. n changing it the night before :) sounds right?
AFAIK Sougi 6000 is gone...well Birds doesn't sell em anymore. Are u leeching off Scotty's stash? :teehee:
If Chrono 300V is 120 per change then I might as well do that...considering I'm paying $80 for Mobil 1 which needs to be changed every 5k...
And the fact that most performance workshops use a generic oil.
At best you can expect Mobil 1 (which certainly isn't bad, but it is no Group V oil)
so im guessing theyd be under the impression im using mobil or equivelent?
makes sense now. would it make a difference for when/after i tune? or is it dependant on how heavy my foot is...
its because workshops live on services, its their bread and butter. no offence intended to any workshop, but if you convince people they need a service every 5000km, they probably will
when JDM S15s came on the market, the dealers (import dealers) were saying they need 5000km services because they are imports. tell me why the same car was sold locally and needed 10000km oil changes?
wasnt this a completely different tune to the ones that were sold here?
but whats your saying does make sense.. but will my circumstance change after the tune??
no but its good to have fresh oil in there when they rev the shit out of your car for a few hours :)
however, if you have to change plugs, do it after the tune as they will probably be fouled and you dont want to do that to a fresh set of plugs
lol too late i've already changed then about 50km before the turbo died.. so they're new.. Cihan advised to change em prior :blink:
yeh i know aboout the revving... not sure if i wanna witness this lol
Same here. He mentioned its so he doesn't have to hunt down a fouled plug during the tuning process...
yeh. although my plugs in the car were pretty new, they were changed on complianced which im told is rare..
good!
i guess he needs a driveline upgrade soon lol
yeh so i heard, which is why mines getting a shift kit installed on monday.
exact words from the RVO guy. "i'm going to up the line pressure as much as possible without breaking shit"
hahahaha.. good enough for me..
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
