Yes, it will last 10,000kms for sure
5000km changes? Bullshit.
10,000km with a Group V oil is no problem... unless you are tracking it.
yes well from the troubles i been having lately, im not being a penny pincher and am doing it every 5000km.
i agree with 10k services. 5000km is overkill for a street driven car
really?
why are all the performance shops saying every 5-7000kms a service should be done especially being a turbo charged vehicle?
fact that im going for a tune on wednesday change anything? or ...
because people pay over $200 per oil change at a performance shop.
do an oil change before the tune
no but this is a performance shop knowing that I'dd do it myself..
yeh theres no oil in the car.. once the turbo goes on im doing a flush, then putting some new oil in, then driving that up to get some Sougi 6000 or whatever it is.. n changing it the night before :) sounds right?
AFAIK Sougi 6000 is gone...well Birds doesn't sell em anymore. Are u leeching off Scotty's stash? :teehee:
If Chrono 300V is 120 per change then I might as well do that...considering I'm paying $80 for Mobil 1 which needs to be changed every 5k...
And the fact that most performance workshops use a generic oil.
At best you can expect Mobil 1 (which certainly isn't bad, but it is no Group V oil)
so im guessing theyd be under the impression im using mobil or equivelent?
makes sense now. would it make a difference for when/after i tune? or is it dependant on how heavy my foot is...
its because workshops live on services, its their bread and butter. no offence intended to any workshop, but if you convince people they need a service every 5000km, they probably will
when JDM S15s came on the market, the dealers (import dealers) were saying they need 5000km services because they are imports. tell me why the same car was sold locally and needed 10000km oil changes?
wasnt this a completely different tune to the ones that were sold here?
but whats your saying does make sense.. but will my circumstance change after the tune??
no but its good to have fresh oil in there when they rev the shit out of your car for a few hours :)
however, if you have to change plugs, do it after the tune as they will probably be fouled and you dont want to do that to a fresh set of plugs
lol too late i've already changed then about 50km before the turbo died.. so they're new.. Cihan advised to change em prior :blink:
yeh i know aboout the revving... not sure if i wanna witness this lol
Same here. He mentioned its so he doesn't have to hunt down a fouled plug during the tuning process...
yeh. although my plugs in the car were pretty new, they were changed on complianced which im told is rare..
good!
i guess he needs a driveline upgrade soon lol
yeh so i heard, which is why mines getting a shift kit installed on monday.
exact words from the RVO guy. "i'm going to up the line pressure as much as possible without breaking shit"
hahahaha.. good enough for me..
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
