Not really. They go back in their because it was the easiest way from factory.
It's a proven advantage to vent them somewhere else. My RX7 has the breather go into a bottle... The optimal setup is a 2L+ bottle, with steel wool baffles and a drain back to your sump.
Oil vapour = lower octane of your fuel and grime up intake. Which we all know is an issue on VQ motors. When I ripped off my intake it looked like someone had poured a bottle of oil through the intake. (Given it probably had never been pulled off its whole life of 200,000km)
Yeh, i'll probably do that, or just get a silicone joiner the same as the black pipe, just a little more dollars.
Just to agree...
They go back in there because it is part of the 'environmental protection' of using all vapours through the engine etc.! Even fuel vapours that come out of the charcoal canister get re-used into the engine.
Optimal setup depends on your sump size, what boost you are running (which to some extent has an effect on blow by) and how efficient the scavenging of the 'catch can' is. Draining back to the sump is good, but you don't want to pressurise your sump, so use suitable PCV valves, and vent the 'cleaned' air back into the factory position. Then less oil gets into the intake and you don't increase your chance of detonation.
The S14/S15 SR20DET has a great factory 'catch can' built into the rocker cover. The design means most of the oil gets returned to the sump, and it still vents back into a 'factory position' after the AFM and before the turbo. Works excellent.
Yeeep. I'll probably just end up getting a nipple put onto this intake, as i'm not after performance on this motor.
Oh and this afternoon got bored, so pulled some peices out of the interior and washed it all. Pulled seats out and vacuumed, cleaned up amp wiring and put it under the boot floor.
So gross what appears over time, the cup holder in the middle was a mix of tobacco and sticky spilt Rockstar/Monster, including under the slip-in peice.
Fitted the throttle body... redet the ECU.
Car wanted to stall a few times on the first drive, but after restarting the car it seems good. Drove around this morning for a bit and no 4wd light yet... which is a good sign so far. Fingers crossed.
Hows your idle? Steady at 650 rpm?
Big day today.
Headed out to AM Performance, who are planning to start producing M35 exhaust systems. Donated my car as the development car, should be getting underway in the next couple of weeks.
Then headed around to my dad's workshop and put the car on the hoist for a service. Was very interesting, gearbox and engine took no where near as much oil was I was expecting even though they were drained.
Have found a couple of things that need fixing through. Rear disks need machining and rear pads need replacing, and need a catch can. Couldn't find any reason for the weird noise that I get occasionally when I lift off, so sounds like new blow off valve too...
And after all that, I forgot to put on the intake spacer I got from Craig! :domokun:
Edit: And no bloody LSD!
Edited by bigkevracer
Big day today.
lol....one day you'll get it done!!!!
I thought you had an AR-X for some reason!
removed front bar and rewired the botton foggies in my aero bar back together as they were cut for compliance reasons. for such a simple job took me about 1.5 hrs inc removing and reinstalling front bar.
do you reckon the little "plug" in line with the OBD port maybe eff'd?
anyway attacked my belts today. pulled em off Cleaned off all the belt grip shit with some degreaser and a scrubbing brush! put new belts on, the squealing seems to have stopped.. hopefully stays stopped
Thanks scott for ya help!
do you have anymore of these Craig ???
I don't but i know someone who does if you interested.....I'll have to check and see if I have a spare Gasket.
PM me for further detail
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
