1J and 2 J's are a proven engine. VQ's are only in the early stage's being a new engine. Sorry that was my toyota side. Split personallity there guys.It will be interesting to see how the VQ30 powered 300zx will go at this years time attack in sydney. should be a great event again. Ok back to topic. I guess ive only put my stagea into the gearbox place to get the slipping box fixed. Bring on the warrenty repairs.
Edited by joshm35
Should be ready to pick up tomorrow or Sunday (might have to beg Brad to give me a lift to pick it up :worship: ) and sounds like it'll be worth the wait. Straight through 3" no restriction :banana:
Yeah no worries its not far from home we can call in after the cruise. Id be keen to look at the exhaust. Im in need of one in the future.
Just purchased a new front diff!!!! 3.538 ratio ftw!!!! Just gotta find a rear now....should make it punch out of the hole even better :P
Edited by Jetwreck
3.54 appears to be the standard ratio for your cars. Have you bought a different one or is your car not currently 3.54 final drive?
OK looks like n/a had 3.54 and turbos 3.13
Let me know if you have trouble finding a rear diff as the majority of NM35s in this country are n/a and I'm sure I could find you one if you want.
thanks for the offer on that.....but I will be chasing 3.538's with LSD and I am pretty sure that the only Stagea that came with a 3.538 LSD was the PM35 AR-X!....If you find one of those that's wrecking it would be great......the 350Z MT and V35 MT both have the diff I need so hopefully I should be able to trip over one soon.
I am hoping this will ratio change will give the gearbox a little less of a hard time.....and also give me some more mumbo all around.
Edited by Jetwreck
I got my car back! :banana:
Exhaust and dump have transformed it. More low end pull, spools up faster, absolutely hammers. Looks the goods too with twin 3" titanium outlets.
Only issue at the moment is its too bloody loud! But we will fix that shortly.
Hooked up the informeter, pleasantly surprised it just works.
Will get some exhaust pics when I get home from work (and we have some daylight). Then in goes the Nismo dash, and a proper mounting spot for the Informeter.
No idea... I definitely won't be complaining about it being too quiet! It can be heard from Japan!
you shouldve gone a Jazma cat back system from Jap and had your exhasut shop make up a dump/front pipe.
mine is 80mm straight through from the turbo to tip. and its still really quiet.(FWIW) .. lol you can actually see from one end of my exhaust to the other lol.
I'll video it tonight..
even cam's noticed it and Cam's picky with this stuff, but he even said.. for a straight through its fairly quiet.
sounds nice on full throttle as well.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
