nope, ARX and AXIS have a larger rolling diameter.
also PM35s are different, also as as 2WD and 4WD models of the PM35 (im only talking about models available in australia)
True Ian; but Ironpaw isn't running STD 17's on his anymore, (due to Brembos?) so his Rolling Dia. (depending on tyre profile) will be close to, if not slightly bigger than an AXIS and only around 3% smaller than an AR-X.
Detailed my car today, in anticipation of it's shiny new Aero Bars (which are taking WAAAAAY too long to get painted); my son of rajab it's a sexy bitch when it's shiny!:banana:
Dodo juice Lime Prime is very nice to use on black paint.
Edited by Daleo
dude post up some pics when its done!! i dont think ive seen a black aero model before...........
as for the wheels, wouldnt wheel weight make a difference too, unsprung weight helps with accelleratiion and braking :)
yeh i didnt want to compare with everyone else. i wanted to see if there was any improvement running the extra boost?
5psi for under 100nm(on cihans dyno) isnt worth it imo..
oh n found out my fuel leak wasnt a fuel leak. the sensor is playin up..
Reflection? post-61153-0-26778900-1310425114_thumb.jpg Try not to look at the ugly bloke; post-61153-0-56895300-1310425163_thumb.jpg
With painted skirts;post-61153-0-59531300-1310425226_thumb.jpg Without; post-61153-0-55007600-1310425328_thumb.jpg
Farrrk I forgot how ugly our cars are without the Aero kit...:yucky:
I know, it looks like the dumb smiling kid at the back of the classroom.
Eating paste...
Hey Dale, who painted the tree mural on your bonnet? Not my choice of artwork but it's very realistic.
Door molds?
Yeah, I dunno; I think they tie the wheel colour in better now, as there isn't won't be so much grey.
Going to wait and see; can always get them done later, they're easy to match. KH3 is straight black tinter.
Edited by Daleo
Ok, I just had my old boss translate the Nissan user manual regarding oils, he is Japanese. It said the front and rear diff uses 80w-90 and made NO mention of LSD or non LSD. If its a clutch type LSD as some are thinking the 80w-90 will be fine, this is what we used in our 2 way clutch LSD's, so we cant see it being a problem.
got a dyno sheet?? what torque figures you get??
700-750nm's.....from 3,000 to end buddy!...what was yours again......at 16psi???.....and was it a flat torque curve or a little all over the place?
.....I'm not worried....I am sure I'll crack 800-900nm / 300AWKW's on BP98 at 20-21psi........imagine if I ran E85.
P.S. Don't diss our housings mofo......they are a pretty good stock unit imo.....not as good as the GTX.....and if I had of has the time, tools, money and room I might have gone that way!....who is to say which has more lag? and who is to say what the HP difference is when comparing apples with apples!post-37023-0-31134200-1310446822_thumb.jpg
what are you talking about man, i was asking Jethro lol.
who said im dissing our housings?
your on drugs again arent you?
Edited by Jetwreck
yeh yours is OK......but I am producing the same as you at 105km's and more at 180km's!!!! :P
you sure about that bud?
Looks like you have 140 at 105kph... he has 160 at the same speed, yes?
Or am I reading it wrong??
I'm reading it wrong down the bottom!...lol
Edited by Jetwreck
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
