OK, so I just fitted the engine cover back onto the car to double check if it will fit with the 17mm plenum spacer. When I fitted the spacer and the cover I thought it was hitting the bonnet so took it back off. Ive been thinking about it during the week and for some reason really wanted the cover back on whistling.gif
I put a nice smear of Vicks vapour rub on the 6 bulges of the cover, then closed the bonnet and started engine and gave it a few good revs. When I lifted the bonnet I found NO Vicks on the bonnet lining. So I am now going to make up some play dough and put a 3-5mm layer on the engine cover and try that. I do this when building my Valiant engines to check piston to valve clearance with a BIG lift cam. This way I can cut it and get a cross section of the play dough to see exactly how much clearance there is.
And I also pulled out the rubber grommets in the cover and turned them upside down, this sat the cover about 2 mm lower.
Edited by slippylotion
I know the cover does look good and keeps the motor looking neater but I can tell you it makes the motor (intake) much hotter than with the cover removed. One of the biggest issues I ave seen with covers left on is the rubber parts becoming stiff and brittle sooner.
Busy day today, gave the car a service, and while I was at it, fitted up:
Fumoto Oil Drain Valve
R34 Intercooler
10psi Actuator
Yellow Jackets Coilpacks
Replaced the HKS pod that came with my car with a stock airbox and Apexi filter
And gave my AFM a quick clean with contact cleaner
R34 Intercooler
10psi Actuator
Good work -exhaust next on the list or is it already done?
Thanks, dump pipe's next on the list. Has factory Nismo option exhaust on it, and like how quiet it is, so wanting to keep that, at least until my daughter's quite a bit older. Just wanted to make it a bit more fun for occasionally giving it a little on the way to work and back :P
Itd be fine (and good price too!) if used in conjunction with a pigyback setup to finetune it for your setup, ie + SAFC + SITC, or + emanage ultimate
ie, like Im running chipped ecu tune + AEM Fic/8, which is emanage equivelant
But in saying that Ive got a z32 ecu here to nistune-chip, once Ive bought a harness patch extension to completely rewire everything. After cracking piston #5, shattering the rings, and cracking the rings on piston #4, Id prefer a full tune via Nistune.
You can do a Nistune tune on the Stagea ECU so you don't need the Z32 ECU.
Sadly you can't Nistune the S1 Stagea (or the R33 Skyline) ecu - only the S2 or R34 Skyline.
It looks awesome!
Replaced my battery Friday night. In the dark and rain, because the other one finally gave up completely.
Should be ordering shocks and disks this week, can't wait!
It looks awesome!
No BC's Ryan?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
