Haven't ordered anything yet, but it's good to know that there are options..
http://fenixautopart.com/products_info.asp?selectclassid=002001028&id=242
Anyone put an alloy radiator in an m35 yet?
Fenix are a good choice - made in NZ, not china, and good local support. Discounts for NSW club members too.
funnily enough, the only email I have is Christiaan [email protected].
Or,
Fenix Autoparts Distributors Pty Ltd
(02) 9648 4668
U 45/ 2 Slough Ave
SilverwaterNSW2128
:google:
350z radiators have the cap on the wrong side.
It will foul with your intake funnel into the airbox.
I am led to believe that the pins at the bottom of the tank that slip into the support holes are located a little too far forward or back (can't remember) on the 350z radiators.
ok installed the castor arm bushes tonight. massive change in the car. worth every cent!
also put the rest of the cat-back exhaust on to see the sound, not a bad note coming from it
aaaand put on the blitz BOV, i get more flutter, but im cool with that. it scares the old ladies around my suburb lol
Sooo... Iain... you'd have a spare stock BOV now, right? :whistling:
Castor arm bushes are those poly bushes Craig was doing, right? Were yours just shagged or are the poly ones that much different?
same poly bush's.....accept he got the set that help fix the pull to the left.
Or,
(02) 9648 4668
U 45/ 2 Slough Ave
SilverwaterNSW2128
As Duncan would know as an SAU NSW member I fitted a 42mm one to the R33 which required no trimming at all but needed a little fiddling with the aircon temp sensor (some R33's have no issues with the sensor).
I also fitted the same one to the stagea which required a small amount of trimming of the central part of the shroud (due to the extra thickness of the core).
Both are working well and quality looks good. Pricing for SAU members and speed of delivery get a tick from me.
yeah i do, another non-farting one lol
yup those are the bushes craig was talking about. mine didnt appear to be stuffed, but it turns out they were. much difference? not really, only a HUGE difference
Thanks I'll try him tomorrow.
Let us know how you get on; it's on my list to do before summer.
The OEM rad is barely adequate in hot weather, and nowhere near good enough once you put a bigger intercooler in front of it; which is also on my list...
Fenix don't do a full alloy radiator to suit M35/V35. They have them listed but they are just 350z ones. Full credit though, once I got onto them the guys were pretty helpful and obviously didn't want to sell me the wrong thing (like SO many people I've spoken to in the last day).
Top of my list right now is a Koyo V35 radiator. Wbperformance.com will do them for USD $405 shipped, just not sure how trustworthy his site is. Otherwise USD $452.50 shipped on eBay.
Since you're in Adelaide, did you just call someone like Tonkins or Adrad? Adrad are Koyo dealers too.
Although I'm rapidly finding out that even with trade accounts a lot of this stuff is cheaper overseas...
Way cheaper. Just rang a place that Adrad referred me to and not only could he not find a part, I asked for a ball park price on a R33 Koyo full alloy radiator (that was what he was trying to sell me despite saying "V35, G35" over and over and over) which was $900.
Tonkins as in the car audio place?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
