Well I got my braided lines and wireless reverse camera in the mail yesterday
When you figure out how to make it work let me know. Mine is useless. Pioneer screen goes black when it kicks into reverse but no images. :rolleyes:
Ask Brad (ducati02). He will be making mine work, he will be able to sort it for you.
Well I got my braided lines and wireless reverse camera in the mail yesterday, just waiting on the rear rotors and suspension now.
Not sure if I'm even getting my suspension now. If I don't hear from Street to Track by tomorrow I'll be reporting to the bank to get my money back. Service is terrible, and still waiting for my shocks 3 weeks later. Now they guy won't even respond to emails. Major disappointment.
Sorry to hear dude. Didn't someone else use them and found get were ok?
I had some major issues with emailing him, was taking hours for the email to get through to him and reply back to return. I thought his provider or mine were very laggy. Hopefully this is the case... Do you have his number?
Either your camera doset have supply when in reverse or your video isnt pluged in. A black screen means there is no video input. Try another video source into that channel.
Re Street-to-Track, I used him for my BC's and found him good to deal with. He replied to my emails by next day at the latest. They did take a while to arrive, but I thought that was 'cause they were custom spring rates. IMO the hold up will be at the factory, but that doesn't excuse him keeping you in the dark. I hope they arrive soon Ryan.
Edited by Commsman
I went through him and to be honest it was a pretty smooth transaction and they arrived way faster than I thought they would. Hopefully it works out for you mate.
So what is the game plan for rear spring removal? Do you need spring compressors?
Thats why I gave him a go, plenty of positive reports on here. But since I handed over the money his attitude changed and giving me the time of day has been a hassle.
I think his number is on the invoice, so I'll give him a call tomorrow.
Na just unbolt the lower control arm from the hub, I have the car just off the ground and a jack to take the load, pull the bolt out and release the jack slowly. Job done. Will take all of about 10 min to remove both sides :)
Mike.
Thanks Brad.. I've pulled out the head unit and made sure everything is connected so my next guess is power.
Mike.
Cheers Mike!
Me and working on cars in a rush does not mix. Just stuffed a high tensile bolt using a little bit too much force. Need more patience! :rolleyes:
Anyone know if 55110FB and 55269+D in this picture is the same as any other Nissan? I've seen this type of bolt before, maybe just on my C34 Stagea. Any suggestions as to where to get one? Try and get one from Nissan or just go to a fasteners place?
:thanks:
Pretty retard move on my behalf. The bolt was a tough one to come off, had a little slit through some of the threads. When I threaded it back on by hand it went a good ten or so turns and then stopped. I figured the thread would come good given just a bit of force and before I knew it I had a very useless piece of metal.
Followed your measurements Dale and they are WAY off hahah. I'm sure I screwed up something. The front end is slammed while the rear end is slightly lower than stock. Might raise the front this weekend otherwise I'll just wait until my wheels rock up.
Edited by jasevr4
Pics!
Apparently mine actually might be coming, STT just don't have any updates, and I get the impression he couldn't care less.
Since he's now over both deadlines he gave me and hasn't even seen a shipping confirmation I have no idea what is going on. But I won't be doing this again.
:thanks:
Would you believe Jetwreck and I (but mostly me) stripped exactly the same bolt in the rear of my car when lowering the rear!!!
Had to go for a quick drive to somewhere we knew there were some similar boltswhistling.gif
Warning to others- they strip easy!
I have to say I feel like a lot less of a retard now.. :rofl2:
FYI the bolt and nut would have cost me $18 genuine from Nissan. The bolt would have come from QLD and was one day away while the nut would be a 10 day wait from Japan.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
