Not what I did to my stagea, but more what I did WITH it..
On the way to nightwars (a summer drag racing series), threw sparks all over everyone elses cars, popped a couple cats eyes out of the road and now all I can smell is hot metal... Flexi in the exhaust looks worse for wear and so does the rear tow hook... Might need to raise it. :(
Don't do it!:spank: As an extension to the "Don't buy wheels that fit the car; make the car fit the wheels" ethos; I propose a "Make the road suit your ride height" solution.
You just need to keep frequenting the roads you use; until you've worn a groove them all to suit your ride height, no more clearance issues.
Anything still grinding will eventually be worn away; consider these items "Surplus to requirement" Problem solved.:thumbsup:
You're welcome.:whistling:
Edited by Daleo
ok this is what i found............. so basically its a wait of money.
Posted 27 April 2011 - 02:24 PMsnapback.pngironpaw, on 27 April 2011 - 01:55 PM, said:
Anyreason these won't work for our cars?
http://www.importmon...%20NM35%2014750
review: http://my350z.com/fo...-installed.html
They will not remove our restriction.
Ask Scott when you see him next how well it worked in that regard.
snapback.pngbigkevracer, on 27 April 2011 - 02:13 PM, said:
If I read the old discussions properly though, Mines wouldn't remove the throttle restriction.
I figure we're not going to get a flash that does everything we want, but a flash that removes the speed limiter and throttle restriction and gives us 80-90% of what we want is fine with me. And when I want that remaining 10-20%, I can get an emanage knowing that the two main areas it can't fix are sorted from the flash.
Mines completely remap the entire throttle map... does that mean they remove the restriction? Buggered if I know.
I asked them directly if they remove the restriction below 3000rpm and they replied "we do not", but they did state that they do remap the entire throttle map up to their normal 7100rpm (they will go higher, but issue a warning of "please consider engine safety").
I think your plan of the Gzone + emanage is almost as good as it gets.
came across this whilst searching ebay for other stuff.................... thoughts ???
Throttle Controller
Yes, a waste of money IMO. You'd be better off spending the $350 on real mods to improve the throttle response. Did you see the claim:
Enhances throttle response OR fuel saving of up to 20% ? I suppose 2% is 'up to 20%'....
Edited by Commsman
new o2 sensor today
was hoping to pull the pins out of the old plug and swap it over, turns out the neo plug has slightly smaller pins :(
3 crimp joiners later and i was away, i think the old sensor was ok but for ~$70 it should help on the way back up to qld
Installed my Walbro 250 pump in my M35 today and set up a power source direct from the battery to ensure full power to the pump at all times.
Reason for changing the pump was following the introduction of Nismo ECU, 3 inch suction pipe and spring on turbo actuator was seeing AFR being too high.
AFR's on medium throttle and below 4500rpm were all good and around 11.8-12.5 but higher rpm and more throttle saw AFR's is 13's.
So new pump fitted and now AFR's are much better at 10.7 to redline.
Now to start playing with boost again to see what the car will handle.
:rolleyes:
:rolleyes:
Hey Andy, that's a big change. Are the AFR's that rich throughout, or mainly heading towards redline?
Have to do a bit more testing to be sure but I don't think they were. Will be able to tell you more tomorrow.
Also got to get the boost controller working again and run more like 17psi.
Nice result & keen to hear what the AFRs are like after running around for a while. Mmm, more boost :thumbsup:
AFR's are
off boost low RPM (0-2500) 13.5 - 14.5
Low boost mid RPM (2500-4500, up to 10psi) 12.3-12.8
High boost full throttle (4500 +, 15psi) 10.7-11.2
Quite happy with these numbers.
Andy, those AFR numbers are pretty darn good. Off boost & mid range is very close to what I'm running. Upper end of rev range / max boost is a little rich compared to what I found works best for my car, so you have a nice buffer to increase boost safely.
Did you get a look at max injector duty cycle now?
I knew someone would ask that...... lol
It is certainly better than on the stock pump but at redline I am getting up to 95% duty cycle but this is with AFR of 10.5 so not too worried about that.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
