How are you going to make the front line up with the flares better?
Getting the front fibreglassed to match...should work....I want the front wheels behind the guard like it is with the AR-X front.
Edited by Jetwreck
:cheers: Sounds like its gonna look the goods!
The rear seems to fit well over them already - does it line up nicely in person?
As much as I'd like to hang shit on you Craig, I really like it.
This makes me sad :(
Could you successfully make the exterior of an ARX look good? If so, how long have you been walking on water? :P
Replaced my 15psi gauge with a 30psi VDO unit.
Turbo arrive from Hyper***r on Monday - minus a banjo bolt that, unfortunately, needs to go in before bolting it up to the exhaust flange. Another public holiday where I'm not able to make the most of my time & get it back together. Just a little bit frustrated with how the turn around time blew out from 3 working days to 3 weeks (plus Easter). In their defence I heard they are short staffed atm, but the poor communication doesn't help either. Grrr. End rant.
I'm sure it will be worth it when it's installed. Visually the in & out ports are significantly bigger. How that translates to power delivery remains to be seen.
Somewhat disappointing Leon, but as you say, hopefully it's worth the wait.
Changing the boost gauge... what boost are you planning on running when it's done?
I hope it's worth it too.
Apparently this high flow becomes 'inefficient' around 20psi. I don't know if that was arrived at by some formula or from experience in the test vehicle. AFAIK the M35 they tested it in was pretty stock (only exhaust & boost controller I think), so maybe it was the intake restriction causing the inefficiency. I've no idea what boost will give the best results. Will have to wait & see (& hit up a dyno for a tune).
In any case I needed a gauge to read higher than 15psi. When my old gauge was first installed it was great as I was only at 13 psi so the resolution was excellent - you could easily see half, or even quarter, psi increments. But as things progressed (running >15 psi) the gauge acted like a boost light - either off or off the scale, lol. Other than light throttle uphill where you could see (say) 4 or 5 psi, it was pretty much useless.
keen to see the boost gauge install im still hangiung to get my car back
You're getting the 'super hi flow' yeah? Very keen to hear how it drives compared to mine (or stock).
Here's my old one. New in same spot but reads to 30. Hard to tell in pic, but it's angled towards driver courtesy of a 50mm conduit joiner cut down. You can see the cut out in the lid needed to close over the gauge. Lid's all hollow so I partially filled with expanda foam then used plasti-bond to give a hard surface & sprayed black. Looks almost OEM.
On the Sierra Stage One any boost over 19psi seemed to make little difference to the performance.
I tried running it at 12psi for efficiency but I found there was little difference in economy and not as much fun as 19psi.
Good luck getting it together soon.
Cheers
Andy
Set of these are on their way for the stagea.
Nissan 370z akebonos with 355mm Project Mu rotors.
Is it true you need 19 inch rims to clear these? Been looking at these for a while.... very jealous :)
Cheers
Andy
Thanks Andy. I suspect I will find the same thing re extra boost resulting in only heat, lol.
I have a low boost setting atm which nets good fuel economy (10L/100km) & hoping that remains similar. I'll take the high boost setting to as much as the fuel system can sustain &/or the gains drop off. Guessing about 19 - 20psi will be max.
Nice placement Leon, that's where I was hoping to fit the wideband. Have you got some better close up pics?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
