How are you going to make the front line up with the flares better?
Getting the front fibreglassed to match...should work....I want the front wheels behind the guard like it is with the AR-X front.
Edited by Jetwreck
:cheers: Sounds like its gonna look the goods!
The rear seems to fit well over them already - does it line up nicely in person?
As much as I'd like to hang shit on you Craig, I really like it.
This makes me sad :(
Could you successfully make the exterior of an ARX look good? If so, how long have you been walking on water? :P
Replaced my 15psi gauge with a 30psi VDO unit.
Turbo arrive from Hyper***r on Monday - minus a banjo bolt that, unfortunately, needs to go in before bolting it up to the exhaust flange. Another public holiday where I'm not able to make the most of my time & get it back together. Just a little bit frustrated with how the turn around time blew out from 3 working days to 3 weeks (plus Easter). In their defence I heard they are short staffed atm, but the poor communication doesn't help either. Grrr. End rant.
I'm sure it will be worth it when it's installed. Visually the in & out ports are significantly bigger. How that translates to power delivery remains to be seen.
Somewhat disappointing Leon, but as you say, hopefully it's worth the wait.
Changing the boost gauge... what boost are you planning on running when it's done?
I hope it's worth it too.
Apparently this high flow becomes 'inefficient' around 20psi. I don't know if that was arrived at by some formula or from experience in the test vehicle. AFAIK the M35 they tested it in was pretty stock (only exhaust & boost controller I think), so maybe it was the intake restriction causing the inefficiency. I've no idea what boost will give the best results. Will have to wait & see (& hit up a dyno for a tune).
In any case I needed a gauge to read higher than 15psi. When my old gauge was first installed it was great as I was only at 13 psi so the resolution was excellent - you could easily see half, or even quarter, psi increments. But as things progressed (running >15 psi) the gauge acted like a boost light - either off or off the scale, lol. Other than light throttle uphill where you could see (say) 4 or 5 psi, it was pretty much useless.
keen to see the boost gauge install im still hangiung to get my car back
You're getting the 'super hi flow' yeah? Very keen to hear how it drives compared to mine (or stock).
Here's my old one. New in same spot but reads to 30. Hard to tell in pic, but it's angled towards driver courtesy of a 50mm conduit joiner cut down. You can see the cut out in the lid needed to close over the gauge. Lid's all hollow so I partially filled with expanda foam then used plasti-bond to give a hard surface & sprayed black. Looks almost OEM.
On the Sierra Stage One any boost over 19psi seemed to make little difference to the performance.
I tried running it at 12psi for efficiency but I found there was little difference in economy and not as much fun as 19psi.
Good luck getting it together soon.
Cheers
Andy
Set of these are on their way for the stagea.
Nissan 370z akebonos with 355mm Project Mu rotors.
Is it true you need 19 inch rims to clear these? Been looking at these for a while.... very jealous :)
Cheers
Andy
Thanks Andy. I suspect I will find the same thing re extra boost resulting in only heat, lol.
I have a low boost setting atm which nets good fuel economy (10L/100km) & hoping that remains similar. I'll take the high boost setting to as much as the fuel system can sustain &/or the gains drop off. Guessing about 19 - 20psi will be max.
Nice placement Leon, that's where I was hoping to fit the wideband. Have you got some better close up pics?
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
