Nice. Question: with the shot of the inside of the main muffler, is that a removable restriction section in there? What is the size in there? Just trying to get my head around these jap systems.
What's the difference between the full mega n1 +rev and the hyper fullmega N1?
Nothing, both are abbreviated names for the M35 exhaust: kakimoto "Full Hypermega N1 +rev" (or any arrangement of those words depending on the translation/seller)
Looks great Dale, that style of round muffler is always going to have a strong note. I bet its not as loud as mine is atm. :)
Dunno mate, at 94dB the N1 ain't quiet
I've also fitted one of my own Chromoly front chassis braces!
The difference in handling is much more marked than I expected.
The front of the car feels much more tied together than before; a bit like increasing the damping of the front shocks. Obviously the lower part of the chassis moves around a decent amount with the amount of grip these cars generate.
I also have a set of R33 GTSt calipers which I'd like to see gone if anyone is interested.
Edited by Daleo
Where did you get the brace from dale?
I made it. :thumbsup:
It's a copy of the Ox Motorsport lower front brace, but fabricated in Lightweight Chromoly tube with steel ends.
I'm going to do an EOI thread tomorrow, but there definitely seems to be enough interest to start producing.
Link; http://www.skylinesaustralia.com/forums/topic/400157-daleos-under-car-brace/
Link; http://www.skylinesa...nder-car-brace/
Don't suppose you would be interested in making the rest of the braces?
http://translate.google.com.au/translate?hl=en&sl=ja&u=http://www.oxmotorsports.co.jp/&ei=c4wYSv70O5PY7AOl_OCvDg&sa=X&oi=translate&resnum=11&ct=result&prev=/search%3Fq%3DOX%2Bmotor%2Bsport%26hl%3Den%26sa%3DG
count me in for a group buy. great work dale
nope its not removable looks like 2.5 in the center i don't know why its so small but its hella loud lol.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
