Haha sure did. Foot flat 100rpm too early and it
Jumps down a gear.
With the lock up how well does this work? It would be good to do this just whilst tuning then we can put back to standard
I just hit a switch and it dumps 12v onto the solenoid. Around town I don't use it, the converter flares too much for it to lock up anyway, so its easy. If you want to keep the factory lockup circuit you would need a 3 way switch.
3rd gear the converter lockup clutch won't hold on mine. It was fine up to around 300kw, after that we had to run it in 4th in which just holds. Hopefully Kewish can fit some extra clutches into the converter, thats the plan anyway.
Finished installing the speakers today. Turned out really well and even got the bigger Alpine Type R front tweeters to fit in place of the factory tweeter. Better sound quality than the standard speakers without all that harsh pumped up mid bass.
Now to decide if I want to upgrade the head unit. Any one knows of a good single DIN unit that plays DVD's and has wifi or bluetooth for music play back? I don't want a screen it it though.
Edited by slippylotion
Pretty easy actually. I just bent up a little bracket to secure it using the factory screw holes and used some adhesive foam strip on the bracket to squash up against the back of tweeter. Now that I think about it, I should have taken a pic of it.
Looks good Paul.
What about this for a deck? http://www.pioneer.com.au/au/products/25/109/281/DVH-P435UB/index.html
Most when I was looking was a single DIN with a fold out screen. I think you've seen mine? Works well.
I got my battery back today. They saved the one with only 1.9V in it, or so it appears.
I got a chemical lesson that I'm sure only Leon would be vaguely interested in, but basically it has something to do with calcium based batteries using fibreglass as an insulator around the Lead. Apparently they don't behave well when their voltage drops below a certain amount (I think it was 3V?).
So while it has likely now had its live reduced by up to 20%, it should be fine for now after some heavy duty charging. Looking forward to chucking it in tomorrow and going for a drive!
LOL. I actually do find that interesting.
I would have put money on that battery only being good for recycling. Good to see you can get some more use out of it. I only hope it doesn't let you down at an inconvenient time. (Actually every time is inconvenient, isn't it?)
Installed a FMIC on the C34 today. Purchased the JJR stealth kit and pretty happy with the result. It's looks the goods, and funnily enough is pretty stealthy behind all the black!! and thanks to front bar it get's a lot of flow to it.
Unfortunately no pics of the install! My phone camera was playing up... I'll get some pics of the finished product tomoz.
One thing I can say is that there was no instructions.. and after awhile I realised it was missing a mounting bracket, so I had to manufacture my own. Big step considering I've never done something like this before.
Also, I hadnt driven it for 6 weeks and since driving it I've found that my car has been reaaalllly laggy and seems to make a lot more noise than it performs. Its hard to explain.. I may need someone to look at it.
Hey Ryan I think your battery wont last very long. It might have 12v but it will only hold around 50% capacity if that. Once they go flat it kills them.
Most likely you've ended up with a reasonably bad boost leak....do you have a boost gauge, and if so what does it show.
Go back around the whole job and check every hose is seated square, and every hose clamp is tight. The easy way to check a hose clamp is to push hard on the screw part - if it turns on the pipe it is too loose. But even if they are tight, the hoses have to be properly seated on the pipes, ie square on and good overlap
Yep. I'll see how it goes. I knew you'd be interested. I can find out more if you want?
Its got 13v in it at the moment, but according to the battery guys it would probably have lost ~20% of its capacity. So it should be fine, but if I'm not going to drive the car for a while I need to hook the battery up to a charger that floats.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
