yeh it was raining. lol i went home and slept. reason as to why im up now. ill swing past after work tomorrow pending pickles...
honestly i wouldnt port it.. wouldnt want the same problem that ended up happening with Vartis' head. f**k that
looking good scotty, how long til your done i want to take a ride in the great white whale :yes:
on another note i made my car SLOWER!...............with a set of Grex Alcon callipers and discs!! ;)
Installed the apex-i cat back I got from ross... Not really happy how it sits. I feel it could stick out about 2-3 more inches but it will do for now. Ill adjust it when I get the rest of my exhaust done.
Fitted front & rear Whiteline swaybars & rear links today (thanks Dale!) - will fit my new SPC rear camber & toe bolts next week & Superpro front camber & caster bushes as soon as they arrive (thanks again Dale!!!)
Car sits about one mullion times flatter with the new bars & would happily crack it sideways around sharp corners under a bootfull of power if it wasn't for the lack of LSD.
Highly recommended mod in the unlikely event you haven't already heard about it.
they look good dale!
Hopefully they'll look even better once they've been coated. :thumbsup: Getting a coat of deep black, and then a coat of 600deg clear to finish off.
Do the GT-T calipers bolt up to the standard hubs w/ standard discs?
They bolt straight up to our hubs with the added bonus of M14 mounting bolts (as opposed to 12mm on R32 GTR & R33 GTSt).
You need the matching 310mm x 30mm GTt rotors.
Looks like it's worth the effort then Dale! Easy solution (if, of course, you don't strip and rebuild/repaint!)
Was less pissing about than I was expecting actually; I had less trouble getting the pistons out of these than any caliper I've ever done.
I chucked them on really quickly in the workshop today, to see what they look like; I'm dying to get them finished now!
Pics once they're done.
OK, so after I bought the new front bar I did a trial fit of it to see how it sits compaired to the old one.
BEFORE:
AFTER: DSC01571.jpg
I'm also in the process of making up some blanking plates for the LED indicators supplied with it. Below is a pic of the LHS blanking plate partially completed.
FRONT VIEW:
Below is the template + LED lights
Why not just incorporate it into the stereo?
Ian, new front bumper looks heaps better!
Huh? It is incorporated into the stereo...it uses the factory head unit and speakers.
If your asking why I didn't buy a BT enabled headunit instead... I don't want to spend hundreds of dollars in parts just so I can fit a single/double DIN unit that won't do what my phone and a $99 WDTV can do. Know any headunits that can support NTFS? I'm sick of being limited to USB sticks for storage.
How does it connect to a head unit for music playback, Is it RCA or via the radio?
It can play back music via BT A2P streaming - the unit connects to the factory system via RCA. I didn't enable it since the AUX in will be used by a WDTV unit.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
