Last week installed and uninstalled apexi zorst. friday I also installed dales underchasdis front brace. Very satisfied with the result.
Looking good! ;)
BTW R33huntme; that's a mean looking nose mate! Side on pics please?
Edited by Daleo
Somehow broke my PWR radiator: leaking after 18 months, only having travelled around 4000km, using only correct coolant. Sucks.
On the plus side, just ordered a GReddy suction kit and Z32 afms...
Unless you know where to get cheap PWRs from....that would be worth fixing.
Not very exciting but replaced the rear gearbox mount (auto)... It has made so much difference! I have been putting up with vibration under load that always got worse in the cold and wet weather. I have been troubleshooting this vibration for ages and was thinking it was the gearbox, front shaft, tyres!
15 minute fix if you have a hoist, was a bit suprised it was worn as my car only has 130,000kms.
Part Number 1132001U01 for anybody that is interested.
Adrian.
done an oil and filter change today the part that sucked was having to jack the entire car up and put in on bricks just to get under the thing LOL
Should have left it outside mate - they do that for you in the Riff
:P
:P
Lol, you've only got to drop below 60km/h.
Wheels gone, on bricks, and your dog has an uncomfortable look on his face....
Bought mine a 20lt drum of Syn X6000 today.
Edited by Daleo
How much was the 20ltr drum? Im due for an oil change.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
