just a suggestion i had a strange whinning noise that i thought was the turbo lacking oil on startup would last a little while and then go away. it was like a nasty queeling noise and eventually i traced it down to the belts on the front of the motor needed some dry lube, WD40 done jack sh*t but helped me find it as its not easy to get ur hand past the clutch fan to lube it up.
dont know if this helps but anythings worth a shot!!!
Thanks for the suggestion mate, I know exactly the noise you're talking about Theo; but this is definitely appears boost related.
Basically as soon as it goes positive manifold pressure; the whine starts. It overlays the normal whine that the turbo has.
Sounds like the t3 exhaust gasket, I have had a few like that. Could be the front wheel rubbing though.
Need a replacement stock turbo? It could be a better option if you don't want to highflow...
Hmm, I don't think it's a leak; I'm going to get it on the hoist and stall it up, we should definitely be able to see/hear a leak if there is one.
Frankly, I'd be happy to stay with the stocker; but who's to say how long a second hand one will last? Are you talking about the one you were running on yours in between setups?
Feel free to PM me if you have time mate; it might be a viable option. :thumbsup:
Edited by Daleo
I don't mind Lainy, I like talking to other people. With the car at my house I should be able to get parts shipped quickly, not taking 2 or 3 months like 'other' members. :P
lol.
lol.
Yeah that Lainy guy is a bit of a member... :whistling:
i got stranded today the damn battery in the key/remote went flat............ unlocked the car with the key and the alarm went off and then tryed to start it but the alarm wouldnt stop so couldn't go anywhere untill i got a new battery in the remote. very convenient when i was at the dog park, luckily a mate lived close by and we ran up to the shops and got a new one.
so for anyone needing a battery the part number is CR3020.
Hmm, I think I asked that Lainy bloke for a part to be measured ages ago, just after he got his hands on the wreck, actually. Still waiting for a reply...
Bloody Skoda drivers! :rant:
Oh yeah, I got my clutch replaced on Friday - out with the supposedly heavy duty Exedy, in with a Nismo twin-plate. Getting used to a new clutch and re-acquainting myself with driving a manual at the same time, after roughly 5 weeks of rolling around in only autos.
Saw your pics Nick; you must've been pissed to find whatever that thing was, that was masquerading as a Heavy Duty Clutch!
I'm assuming that was a workshop job? Good to see you've got what you paid for this time.
How are you finding the Nismo clutch? I was going to go for the coppermix single plate when i did my manual conversion, ended up being a bit too expensive at the time though.
Nah, I bought the last clutch myself, Dale, and had Unigroup install it.
Sourced the Nismo myself again, but Unigroup were flat-chat and I wanted my car back, so I got another local mechanic to do it, about 2mins drive and in the same suburb as Unigroup. We deal with them a lot, so I know they do good work too.
Oh, and here's the supposed "heavy duty" Exedy job - less than a year in the car:
It's butter-soft, Brian. Loving it so far! And no, it wasn't cheap, but they do come with a matching lightened flywheel which kind of makes up some of the cost.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
