Update: they're now claiming that incorrect coolant has caused both buildup in the radiator , and they don't cover warranty for corrosion...?!
Last time I checked, corrosion caused the opposite effect to buildup. Coolants used have been as per their rocommendation since the beginning.
They claimed that straight water came out of the radiator when they received, which we politely explained was due to me having to refill it to limp the car 8km to my mech after the car was towed home from the last Stagea cruise.
It's getting pretty frustrating now, but I'm adamant that we have done nothing wrong. The real pain is not having the beast on the road during the coldest part of the year!
Will update when things progress...
Wrong Coolant eh? What a coincidence...
checked all fluids n gonna give it a revtune tonight to get it read to run the 1/4 mile tomorrow
Good luck with that. I hope you get a good time. Nay, I'm expecting you to get a good time (for a M35 anyways).
I too wish you luck!
I'm going to take a punt. 13.2 at 114mph.
That's my guess.
Good luck buddy, still a few teething problems with mine, I'm not sure I want to hit 200kph on the new disks/pads, that and I had a couple of cooler clamps let go today. I will try to have it ready for the next one. :)
had 4 runs all of em shit haha. first run couldnt stall it up and get it on boost (same problem as every other run) and ran a 12.9 @106 which i was happy with first shot, every other run i missed a gear change or couldnt get it on boost so just went home. stalled it up on my street and it cam on straight away haha oh well
We did 2x Cooling mod (yes Scott, heaps of pics for ya) and 1x plenum spacer today... hub bolts, spacers and wheels tonight or tomorrow
Plenum + spacer
Cooling Mod
Also meshed in that little opening in the timing chain cover
Why? Well this is what we found between the heads (under the runners) in a V35
Seems it can make for a nice warm little home for mice :/
Mate, enough with the excuses, lol. There's no need - that's a great time regardless. Good job :cheers:
Today I pulled the passenger side valve cover off. Getting pretty quick at removing the plenum, associated plumbing & wiring (it's my 3rd time afterall :( )
This time there's no sign of oil leaking past the gasket so I must have got it right last time. Afaik that only leaves the banjo oil line on top of the turbo as the culprit. Looks like the turbo's gotta come out again, & that's gonna take a lot longer :/
Sniff...makes me sad.
Edited by Commsman
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
