Changed cabin filter and ordered pass side cam cover gasket. I bought a repco carbon activated replacement filter for $25.
I bought the carbon style cabin filter and still get a lot of fume smells in the car from other cars, do you guys get the same?
Edited by slippylotion
Are you sure you aren't smelling yourself? :)
I assume you ordered the cam cover gasket because it's leaking oil. That'll slowly drip onto hot things & is right below the air intake.
That was the big indicator for mine & no, never noticed it before.
It could be me :yucky:
Yeah I noticed the gasket starting to leak a tiny bit so thought Id get straight onto it. The smell I get is exhaust fumes not burning oil. Ill check tomorrow that I put it the correct way up, The arrow should point up yeah?
Arrow? Not sure, but here's one I prepared earlier.
Does that mean you'll have a spare once you're all done?
An unknown donor sold a busted up turbo to a guy in Brisvegas. He generously lent it to me to be hi-flowed & I sent mine back which has now made its way to Dale.
Afaik the spare is to be offered to whoever buys his car, but there must be a few units around that could be used by the community for these swaps...?
Beat me to it Leon; As you said, I was very generously allowed to borrow this unit by it's owner, so I can't speak for it's ongoing availability.
Ah, I see.
Is there a particular reason most people opt for a high flowed stocker over a new off the shelf unit? Simply ease of fitment?
Or does the M35 have a unique flange design or something like that?
Pretty much; both air intake pipe and hot side pressure pipe are bolted to the housing, and have a very tight clearances on their pathway through the engine bay. Also, you'd likely end up having to go custom on your dump, depending on housing v's exhaust flange orientation.
So there's a decent bit of fabrication to do just to get something different to fit.
Scotty would probably be the best bet for some photographic evidence on what there is to deal with.
For the power I'm after; it's not worth the arseache of refabricating all the pipework.
The starter motor decided to die (at the mechanics??) the other day... After searching around on here and going with peoples recommendation that a RB30 VL starter motor would fit... it DOESN'T! Luckily Repco do returns...... Ended up servicing my old unit (Discovered the brushes were worn out)...
My mechanic reckons its a bitch of a job to get it in and out for anybody looking to do theirs
Nismo extended wheel bolts, 10mm spacers + wheels
Derale transmission cooler and trans service
Gave it a wash (finally).
Next weekend = 50,000km service
Getting there, slowly :)
Where are the pics though?!
where did u get the extended studs from cam? and how much? interested in getting some
Mine died last week, I was told a vl turbo one would fit (not a NA)? I went for a new Mitsubishi for rb26. $350.
Was a 5 min job to fit once the intake is off...
Servicing the old unit was 160 which wasn't too bad.... Repco didn't have any of the Skyline models listed (you think they would right)?
Anyway all good now, I think the RB25 may be harder to work on due to the i/c piping etc doing laps above the engine :down:
Extended studs I purchased from RHDJapan.
2 sets of these although they do 60mm as well
http://www.rhdjapan.com/nismo-long-hub-bolt-50mm-5-lug-front-and-rear-14-3-50x10-55526
You did it from the top????
It's a 15min job from underneath.
Doing a cooling system flush after finding this crap
Ive got no crap in the oil and its not over heating so hopefully just poorly maintained and not a head gasket.
Its got the same sort of texture as mud and its brown...
Edited by theferris
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
