Changed cabin filter and ordered pass side cam cover gasket. I bought a repco carbon activated replacement filter for $25.
I bought the carbon style cabin filter and still get a lot of fume smells in the car from other cars, do you guys get the same?
Edited by slippylotion
Are you sure you aren't smelling yourself? :)
I assume you ordered the cam cover gasket because it's leaking oil. That'll slowly drip onto hot things & is right below the air intake.
That was the big indicator for mine & no, never noticed it before.
It could be me :yucky:
Yeah I noticed the gasket starting to leak a tiny bit so thought Id get straight onto it. The smell I get is exhaust fumes not burning oil. Ill check tomorrow that I put it the correct way up, The arrow should point up yeah?
Arrow? Not sure, but here's one I prepared earlier.
Does that mean you'll have a spare once you're all done?
An unknown donor sold a busted up turbo to a guy in Brisvegas. He generously lent it to me to be hi-flowed & I sent mine back which has now made its way to Dale.
Afaik the spare is to be offered to whoever buys his car, but there must be a few units around that could be used by the community for these swaps...?
Beat me to it Leon; As you said, I was very generously allowed to borrow this unit by it's owner, so I can't speak for it's ongoing availability.
Ah, I see.
Is there a particular reason most people opt for a high flowed stocker over a new off the shelf unit? Simply ease of fitment?
Or does the M35 have a unique flange design or something like that?
Pretty much; both air intake pipe and hot side pressure pipe are bolted to the housing, and have a very tight clearances on their pathway through the engine bay. Also, you'd likely end up having to go custom on your dump, depending on housing v's exhaust flange orientation.
So there's a decent bit of fabrication to do just to get something different to fit.
Scotty would probably be the best bet for some photographic evidence on what there is to deal with.
For the power I'm after; it's not worth the arseache of refabricating all the pipework.
The starter motor decided to die (at the mechanics??) the other day... After searching around on here and going with peoples recommendation that a RB30 VL starter motor would fit... it DOESN'T! Luckily Repco do returns...... Ended up servicing my old unit (Discovered the brushes were worn out)...
My mechanic reckons its a bitch of a job to get it in and out for anybody looking to do theirs
Nismo extended wheel bolts, 10mm spacers + wheels
Derale transmission cooler and trans service
Gave it a wash (finally).
Next weekend = 50,000km service
Getting there, slowly :)
Where are the pics though?!
where did u get the extended studs from cam? and how much? interested in getting some
Mine died last week, I was told a vl turbo one would fit (not a NA)? I went for a new Mitsubishi for rb26. $350.
Was a 5 min job to fit once the intake is off...
Servicing the old unit was 160 which wasn't too bad.... Repco didn't have any of the Skyline models listed (you think they would right)?
Anyway all good now, I think the RB25 may be harder to work on due to the i/c piping etc doing laps above the engine :down:
Extended studs I purchased from RHDJapan.
2 sets of these although they do 60mm as well
http://www.rhdjapan.com/nismo-long-hub-bolt-50mm-5-lug-front-and-rear-14-3-50x10-55526
You did it from the top????
It's a 15min job from underneath.
Doing a cooling system flush after finding this crap
Ive got no crap in the oil and its not over heating so hopefully just poorly maintained and not a head gasket.
Its got the same sort of texture as mud and its brown...
Edited by theferris
    • Nah that is not actually a lot. Just painting my GTR frontend and the little bits to make sideskirts/nismo flare pieces work correctly/fit on the sedan/mount up correctly came to about $7000. Is it a lot? Sure. None of this is economical. Economy would be shelling the car and buying a 2010 Corolla to commute in. The perspective of all of this is different.
    • I have the 2025 build re003s’ on my 06 XT Forester Turbo and I quite rate them for street wet and dry
    • I don't see any issues here. I've been saying all along this is a big job, the price reflects that.  When the car comes back perfect I'm sure it will feel like money well spent.
    • Remember, take original quote. Double it. Then add a bit more. It's how any project goes.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
