Made a resilient mount for my bc solenoid valve.
Tried a foam backing first, still could hear the hammering resonating through my bracket.
Silent now....
Also painted my master cylinder stopper Nissan under bonnet white (aka rustkill rattle can satin white).
I want the engine bay to look like everything was there from the beginning.
I grabbed a GKtech r33 spec one that someone mentioned was in a clearance sale....
Cooling mod received today - thanks Scott!
Will try and get it in this weekend. Radiator and hoses are due Monday, but will take a couple of weeks to get around to fitting. Once the radiator is here I also want to see if we can make up a custom fan shroud to run thermos before the radiator goes in.
Back in QLD at last, awesome Stagea fun times to be had now
Fitted my gktech BMC stopper
Billet shift knob
And Cusco strut brace :-)
Still to go: white line sway bar, ebc and magnetic drain plug
Waiting to see how badly scored the bores are, then it's on to ordering new pistons rods and incidentals.
Does anyone know if R33 GTR front strut braces fit a C34 S1 RSFour?
Also looks like I'll be getting the PFC EL commander to replace the oldschool, scratched unit I have moulded behing the gear stick: I may actually be able to read it... ;) between nasty scratched lens, and the heat from the trans tunnel, the LCD unit is Very hard to read on the fly...
Billet shift knob
Welcome back to QLD! you must be pumped to be back with the Stagea. If you had a simple bleed valve, as I did - you will love how much better an EBC is. Which one did you get ? Also did you buy F+R swaybars ? Will be interesting to hear more feedback on them.
Can't help with much, but if you want to - try some 2000 wet n dry / scotch brite, then autosol or toothpaste on rag/buffing wheel. You may be surprised about getting rid of alot of scratches from the LCD
So happy to be back
Currently running a turbotech v2 and will be setting up the blitz SBC when I can be bothered to do the wiring lol
Only front sway bar (gtr) item but it came with the HD links which will replace my rattleing stock ones
Not sure how much of an upgrade it will be over the stock item but I'll report back once its in
Yeah: thought about that, but realistically, the heat from the transmission making the screen go dark is the major issue: thinking I'll just bite the bullet and go LED. Plus, it's nice to have new stuff!
In the meantime, I'm getting the front windows tinted and repainting the wheels and brakes so the whole car will look pretty fresh when it finally hits the tarmac again...
Not exciting but I washed the front half of the 25G. We are on tank water here , and as it has not rained for nearly four months the tanks are low.
If I had washed the whole car I would not have been able to have a shower tonite.
Finally went round to Supershit and picked up a cheap mobile phone holder to mount the Informeter to the vent. It's been out of the car for over a year, so it's about time it went to good use.
I think there are a few guys with them mounted this way. Bracket cost about $10, I think it should work well. Should be useful with the upcoming changes to the cooling system and intake, to measure the before and after.
post-34363-0-08008100-1352368848_thumb.jpg post-34363-0-75945600-1352368960_thumb.jpg
And while I was taking pictures, I don't think I ever posted any of the EVC setup...
So I mounted the display over between the cluster and the pop up screen:
Under the bonnet, I'm hoping that it's pretty subtle:
With the stepper motor mounted under the new battery cover:
post-34363-0-76641800-1352369238_thumb.jpg post-34363-0-67864400-1352369282_thumb.jpg
The extra wiring you can see next to the stepper motor is for the F-con intake temp and MAP sensors. The FPR will be mounted on the left, next to the stepper motor.
Saturday morning I'm going down to fit Scotty's cooling mod, then I'll hopefully leave the car with AM Performance next weekend to finish the intake while I'm in Melbourne.
Still no intake?
Still no cooling mod?
:P
Hey, I got the cooling mod Tuesday! I didn't have any silicone otherwise it'd be in already! :nyaanyaa:
Intake is waiting for Andrew to get an opening, he's pretty busy at the moment.
BTW Scotty, PM me your phone number, might try and drop by when I'm in Melbourne if you're about.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
