first time it was coming up left bank rich, then after a dyno run weeks later to check it........ it now comes up with left bank lean.
hasnt done so for a few weeks though.
also how can it know its the left bank when it's only got the one O2 sensor observing both banks at once.......... haha
Stupid farking ECU. Must be a way to trick it.
Also noticed boost seems to be spiking which wasn't seen on the dyno sheets first time around. Scotty's wastegate mod will be here soon, hopefully that settles the boost down.
I sent it today Ryan, you should see it before the end of the week.
Your controller won't be having an easy time trying to control boost, the actuator will definitely help it.
Had the tune sorted out this morning. Idles much nicer now, and throttle is sorted.
Fault code was throttle circuit, had some weird behaviours (like fault light going on and off with throttle press/release with the stock ECU plugged in), but after clearing everything, resetting, and verifying, it now feels really good.
Now to enjoy it!
Also just paid rego! Woooo
This should be fun, tassie just updated to stickerless rego but qld hasn't
Yellow stagea
+ qld
+ tassie plates
- rego sticker
= .... we'll find out i guess
Now to enjoy it!
Was that because the throttle map was not set up correctly initially Ryan?
Nope. I can't find a blank table referring to throttle mapping, and according to the tuner a blank F-con table should leave the ECU to control that function.
They have no idea what caused the fault, but I'll just have to keep an eye on it and if it reoccurs its either a problem with the throttle position sensor or a problem with the wiring harness for the cruise control.
Shitloads better though. SHITLOADS!
Drove home today, fault code free until not far from home... when the left bank lean and some kind of left bank voltage error codes popped up.
Throttle is still fine though, I'll have to see if I can find some kind of solution. Fingers crossed!
Car is now sitting out the back... tomorrow night I should start on the cooling overhaul. Unless the Scotty Actuator turns up tomorrow, in which case I'll be chucking that in :D
Do you have any way of seeing the O2 correction that the stock ECU is reading? If so, is it cycling- counting up and counting down? That'll be whats causing the error codes, I'm sure its to do with the way everything interacts and not your actual AFRs changing.
i don't, no. Is this something the Cypher cable can do?
I'm sure there would be a way to loop the signal back.
AFRs look fine on the wideband so I'm sure they're not actually changing.
Yes, the cipher cable will show you the info, but without the reflash ability, you can't get rid of the code. In my car its as simple as selecting the fault code and turning it off, then reflashing.
Its about the end of my ability- I don't know how the FCon is manipulating the ECU data. Best to get them to have a play with the O2 functions within FCon, and see if its able to take the role of O2 correction on.
Oh boy, where to start.
The stock ecu is trying to adjust the fuel rich and lean many times a minute. If it doesn't see a corresponding change on the narrowband it will throw a fault. How can it do this with no control over the fuel anymore? There is no way to send a matched but delayed signal back to the ecu, you could throw it some random sine wave but our ecu is way to smart for that.
The wideband will show a set AFR at idle with the HKS, the stock ecu would normally be cycling a rich/lean pulse not holding a stable afr. Using the narrow band output from the wideband controller won't change anything.
Can the HKS take over O2 correction, using the factory fuel target table (because FCon won't let you enter a target table), with either a wideband or narrowband feedback?
Should work (theoretically) with factory injectors- any bigger injectors, the section in the target table for AFR correction would be to big and you couldn't tune correctly.
Why would you want factory style correction anyway?
Target AFR's perhaps, but you would have to rely on the wideband a little too much for my liking. Without a full standalone we are frigging around in the dark.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
