first time it was coming up left bank rich, then after a dyno run weeks later to check it........ it now comes up with left bank lean.
hasnt done so for a few weeks though.
also how can it know its the left bank when it's only got the one O2 sensor observing both banks at once.......... haha
Stupid farking ECU. Must be a way to trick it.
Also noticed boost seems to be spiking which wasn't seen on the dyno sheets first time around. Scotty's wastegate mod will be here soon, hopefully that settles the boost down.
I sent it today Ryan, you should see it before the end of the week.
Your controller won't be having an easy time trying to control boost, the actuator will definitely help it.
Had the tune sorted out this morning. Idles much nicer now, and throttle is sorted.
Fault code was throttle circuit, had some weird behaviours (like fault light going on and off with throttle press/release with the stock ECU plugged in), but after clearing everything, resetting, and verifying, it now feels really good.
Now to enjoy it!
Also just paid rego! Woooo
This should be fun, tassie just updated to stickerless rego but qld hasn't
Yellow stagea
+ qld
+ tassie plates
- rego sticker
= .... we'll find out i guess
Now to enjoy it!
Was that because the throttle map was not set up correctly initially Ryan?
Nope. I can't find a blank table referring to throttle mapping, and according to the tuner a blank F-con table should leave the ECU to control that function.
They have no idea what caused the fault, but I'll just have to keep an eye on it and if it reoccurs its either a problem with the throttle position sensor or a problem with the wiring harness for the cruise control.
Shitloads better though. SHITLOADS!
Drove home today, fault code free until not far from home... when the left bank lean and some kind of left bank voltage error codes popped up.
Throttle is still fine though, I'll have to see if I can find some kind of solution. Fingers crossed!
Car is now sitting out the back... tomorrow night I should start on the cooling overhaul. Unless the Scotty Actuator turns up tomorrow, in which case I'll be chucking that in :D
Do you have any way of seeing the O2 correction that the stock ECU is reading? If so, is it cycling- counting up and counting down? That'll be whats causing the error codes, I'm sure its to do with the way everything interacts and not your actual AFRs changing.
i don't, no. Is this something the Cypher cable can do?
I'm sure there would be a way to loop the signal back.
AFRs look fine on the wideband so I'm sure they're not actually changing.
Yes, the cipher cable will show you the info, but without the reflash ability, you can't get rid of the code. In my car its as simple as selecting the fault code and turning it off, then reflashing.
Its about the end of my ability- I don't know how the FCon is manipulating the ECU data. Best to get them to have a play with the O2 functions within FCon, and see if its able to take the role of O2 correction on.
Oh boy, where to start.
The stock ecu is trying to adjust the fuel rich and lean many times a minute. If it doesn't see a corresponding change on the narrowband it will throw a fault. How can it do this with no control over the fuel anymore? There is no way to send a matched but delayed signal back to the ecu, you could throw it some random sine wave but our ecu is way to smart for that.
The wideband will show a set AFR at idle with the HKS, the stock ecu would normally be cycling a rich/lean pulse not holding a stable afr. Using the narrow band output from the wideband controller won't change anything.
Can the HKS take over O2 correction, using the factory fuel target table (because FCon won't let you enter a target table), with either a wideband or narrowband feedback?
Should work (theoretically) with factory injectors- any bigger injectors, the section in the target table for AFR correction would be to big and you couldn't tune correctly.
Why would you want factory style correction anyway?
Target AFR's perhaps, but you would have to rely on the wideband a little too much for my liking. Without a full standalone we are frigging around in the dark.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
