Had my first track day. originally sold my ticket as my cars only semi tuned and was just going to leave it in the show and shine(the reason why i took my bumper off to attract some attention lol). And eventually caught the bug when i saw the guys going around.. going around half throttle though, cant wait till shes fully tuned :yes:
only did two runs my faulkens where chewed, this tracks not really not much of a track its called midvale speed dome in perth and is used for defensive driving etc.
Sounds awesome mate! When it's finished you'll have to get some numbers too!
Mine has had so much neglect lately I went to move it today and the battery was dead :/
It's on charge now, hopefully it bounces back so I can muck around with the F-con tomorrow. If I can get the damn throttle working again it's going in to get retuned after fixing the boost spiking.
my battery was dead as well do went for a larger 4x4 battery and what an a** it was to get in. Also installed my sway bars and gave her service and a good looking over for busted hoses, leaks and seals. tomorrow i'm going to install my standard intake along with changing both diff oils and transfer case oil.
When did you do trans fluid Josh?
I find it easier to do trans, diff and transfer case at once. They come up at about the same fluid interval so easier to remember one date/kms.
You'll enjoy the sway bars.
Thought of going bigger battery. If this needs replacing I might.
with the bigger battery you will have to remove all plastic surrounds and move the fuse box to get it in there and then put it all back where it was. with the hold down clamp I just turned it upside down to fold battery inplace
What's the story there Josh? Did you have a different one that didn't work out?
I took mine for skids, it went OK for a tow car including a quickest time on one course.
All good infact, until Ryan beat me in the white stage battle run! Good driving mate
Battery charged up, back in the car, all good.
Got energetic and mucked around with the F-con. Got the throttle working although now it seems to need a retune. Now that I think I know what was causing the issue I've got back to the tuners, hopefully they're good enough blokes that they'll stand by their work and fix their mistake.
was nice to finally meet you Duncan and nice Stag!!!
Has anyone on here used the ebay throttle controllers in an m35 yet?? Would they work
They work, but mine sometimes threw a tps code, just like the cruise control. :/
All they do is adjust the throttle curve, it will never get rid of the restriction. Only the brake wire cut mod will fix that.
What?
C'mon Scotty, you're only guessing that is the cause :no: . Pretty sure Ryan proved otherwise by disconnecting/reconnecting cruise control. Appears to only be an issue with (some) people running F-Con & given all the wiring changes involved with F-Con installation......
No one else with cruise control has reported TPS codes & most have had it working for over 12 months (mine over 18 months). Probably a combined error free distance of over 150,000km.
What?
I've proved the issue isn't cruise control as the issue continued with the cruise control disconnected, but solved itself when I disconnected the F-con (but had cruise plugged in).
The wiring for F-con install is easy Leon - it's plug and play (pretty much) intercepting the ECU plug. So I don't think it's wiring related.
I've found that the throttle issue was solved by changing the Conversion Table settings, but it needs a retune now. That, and my wiring is different as I'm running the HKS MAP and IAT sensors.
Thanks for confirming that Ryan.
Really, a mod for a M35 that's PnP ??? Must be a first, lol.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
