I hear a certain m35 owner has got his hands on a sought after nismo cat back exhaust!
I'm sure his neighbors will appreciate the lack of truck noise when he goes test driving now
Hah hah.....Nismo fitted.
Sounds very different to vq25.
Oh....I have mofo 20psi launch again if I want it....so much so that the brakes could not hold it. It also needs a tune before having a run as its running way too rich.
Second biggest win is the front end rebuild. I have finally fixed the vibration under load.
  • Like 1
What was the problem? I get a vibration in the GTR sometimes under heavy loads in the front. It also happens more when accelerating down a hill.
Pulled the front cover of the vq25 again to find out where this oil leak came from. Turns out when we done the cam chain replacement we cracked the rear cover a bit. So cleaned everthying up. Got some steel knead it and hopefully its done the job. This time we made sure we followed the service manual. Letting all the silicone go off then top up the oil and fingers crossed its fixed tomorrow.
I'm Pretty sure is was my steering rack.
Decided I'd attack this water leak. When we fixed the oil leak, my cousin removed a thermostat housing bolt think it was a front cover bolt. Not realizing where it was from, everything went back together without it. So I put it back in and no more leak. Will take the car for a good long run tomorrow and try sort out this warm start issue.
I just fitted R33GTST front and rear brakes on my WGC34, I am just running the std master RDA rotors and pads it works and feels great. So much better than the factory cast crap brakes.
I recommend this to all stag owners.
taken the M35 for a drive this morning, no oil or water leaks.
But came home turned it off went to start it and it wouldnt do its warm start again, ran a fault check straight away and got these 2 codes.
P1110 Intake Valve Timing Control, LH Bank
P1136 Intake Valve Timing Control Solenoid Valve, RH Bank
​So im guessing that's the VVL front cover on the passengers side?
Any help where the drivers side solenoid valve is?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
