BTW, my HPX pads and DBA rotor combo squeals quite badly. I'm guessing this will settle down eventually?
Also, where can I get a centre badge for the steering wheel, any ideas? It's still got the S15 "S" in the middle.
We have HPX in our daily; the bed in is critical. They seem very susceptible to overheating during bed in; this draws the pad bonding materials to the face of the pad.
All of it was done without going over 60km/h, 10 stops down to 10km/h; no squeaking or squealing.
People think because they're a quasi "performance" pad, that they need to be bedded in at 4 billion km/h and until fire is pouring out through the spokes of the rims.
If they've been overheated in bed-in, they may bed salvageable; but they may not be.
Chamfering the pads may help, as may lubing shims, etc.
The combination of HPX pads & DBA rotors seems to present this issue more often than other combos, but I don't think it is an incompatibility issue per se.
Just got my Stag back from the mechanics after not having it for almost just over 3 weeks. :lol:
Four welch plugs replaced
Turbo swapped to one I provided - stock V45 (old one had a mad squeel and it couldn't have lasted too much longer)
Cam seals
Crank seals
Clutch slave + lines
Some block oil seals that were leaking apparently
Flushes and liquids
But have you made that decision without actually trying it first? I'm guessing you have. While I'll agree that steam cleaning bustier carpets can damage the pile, using a steam cleaner on crotchless carpets can invigorate the weave and provide a pleasant warming sensation. They don't call it a Rug Doctor for nothing you know.
Edited by Hertz Donut
I got my stag 'beached as' yesterday. The driveway at my new place has a ridiculous hump at the start, and I wanted to make sure I would make it over it...
Turns out NOPE! Haha.
So it looks like I will be raising the height an inch or so... Damn... Lol!
I'd just cut up the driveway!!! or buy a new house!!!
Haha! I would definitely redo the driveway if owned the place, but unfortunately just renting... :(
Yeah the two wheel deal happens a lot also... Seriously need to have stern talking to who ever design these driveways... Haha!
Hmm, well I don't think squeal settles, only gets worse in my experience.
Obviously the guys re installed all the shims and things, maybe go through the bedding procedure again, and see what happens. Mechanics tend to be a little fast in the bedding and don't do it properly. If still bad, rip the pads out, clean, reassemble with gunk, and maybe file the pads.
My HPX are perfect on the stagea.
I hope not.
I'm going to check with them, but I'm assuming that the shims went back in.
Still got a Cat in the exhaust?
Yep, it's still there. It has been modified a bit, but not enough to run the risk of a $10k fine from the EPA. Apparently even the best Cats show restrictions, despite what they're supposed to achieve with their advertised flow rates.
Well, last night (Friday) I went out for a feed, then took it for a bit of a drive and on the way home I went into a quiet, flat part of the industrial area near home and did some bed-in from roughly 50km/h to 10km/h with a fair bit of pressure, and it helped a fair bit. I did about 7 stops, harder than I normally brake, but not nearly anywhere hard enough to trigger ABS.
When I go for another drive, I'll know for sure. Either way, I have to go back to Unigroup to give feedback on how it's all going, and in case anything needs tweaking, so I'll have a chance to ask about the shims and the brake goo.
got a replacement headlight for my condensation filled passenger light.
gave it a good clean....mmmm
from
to
sick of the stag looking like it has a black eye.
also test fitting eyelids...which i cant seem to get to fit quite right.
brought a heap of stuff for the old girl of ebay this morning, got cargo net, nismo springs, rear light to replaced the scratched one, hicus bar, roof racks (will help with moving all the stuff)
It apparently has protectant in it so we shall see how long it lasts.
I've used the same stuff and used all of the sealant on both headlights and now after about 5 months they're starting to yellow again. Probably need to source some more sealer from somewhere...
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
