They do seem to run a little richer on boost than OEM, I suspect they have a slightly different airflow/Voltage curve. Only the modified cars seem to display the rich running, at least it's better than lean mixtures I guess. Did you reset the ecu before fitting it Josh?
The problem is the 'replacement' Nissan AFM's run much the same as these, and only last a short time in comparison, (something gets damaged inside at full noise for some reason.) I have yet to hear of a failure from these aftermarket afm's, and the price is much more reasonable.
Gives you a good reason to tune the car Josh. :P
Yes a good tune is next on the list once I get a ecu. Was thinking wolf 3d(to give us another ecu option) or greddy emanage ultimate(already tried and tested). Found when I was giving it a little using triptonic once I went from say 1st to 2nd gear it kinda stalled/stuttered.
Well, I bought the red S1 off ebay. Price was OK for S1 Dayz with electric leather. Duco is sh#t but does not make it go or stop. Motor was advertised as stuffed, and it is. Compression test was my worst Chrissie present 3,5 & 6 50psi. So out with the motor and it looks like an RB30/25, same as the Sil is the way to go.
So my new year of Deeper in Debt continues. One would think at my age I would know better But then I am a Nissan Man.
Happy SAFE motoring for all for 2014..
Took the HKS pod filter out and put the factory air box back in with a Greddy high flow panel filter. Hopefully it will be a bit cooler than the pod filter and if I was to get pulled over, it isn't a defect.
Have you got a cold air deflector? That is supposed to help also.
Yeah, I have that. Kept all the stock parts just in case. Although it is a PITA carrying this stuff around when you get posted around the country every few years.
Hmmmm looks like your going to need a 4wd sump adapter and oil pick up for that mission
Hmmmm looks like your going to need a 4wd sump adapter and oil pick up for that mission And a lot of dosh.LOL
My Nismo son is doing the Sil Rb30/25 so he does the hard yards and I learn from him for a change. I have been looking at a better oil pump system
for my other RS4 Auto. It has an FFP and a pod and it runs a bit too hot and gets the gurgles I have an oil temp gauge and it gets to 120 when pushed up Henri Robert Drive.. I am looking at an oil cooler, but with a remote oil filter and an oil cooler I think I will need a much better oil pumping system. First I will go like Hanso and refit the stock air box and the cold air deflector. Mrs66 will appreciate the lowering of the induction noise.
Hugh have you put a bigger transfluid cooler on the auto RS4? If it is still routed through the bottom of the radiator that should help. I presume you are using a good synthetic oil! I had a remote filter system but gave up on looking for a place to put it so just got a sandwich plate where I can screw the filter on as its not too hard to do under the FFP.
And what have I done to my Stagea lately? Finally fitted the stock rear wing I bought ages ago, got my under mirror rust cut out and will paint shortly. I got tired of buying cheap and nasty wheels for the track and thought why don't I use my lightweight forged TE37s and bought some Direzzas to try. For the street I got a set of 18 x 8in wheels (ex Nissan GT coupe SE) which actually fit ok. I seem to have lost the ability to paste links on here (anyone else or is it my computer?) so pics will have to wait.
Also removed the knock-off Aerocatches which lasted less than 6 months and installed the much superior genuine article.
(BTW was having a number of problems with this site - unable to paste links etc. Just uninstalled IE11 and reverted to IE10 - all seems to be fixed)
"KiwiRS4T" watch out the heads of the bolts on the bonnet pins will rust out with rain, didn't have a problem washing my car but after it rained they left nice rust lines all down my bonnet :(
No worries have already replaced with stainless!
Tried to rationalise that it's just a car and was not worth commiting murder over because my mother-in-law didn't even notice she'd clipped another car with it pulling out of a car park. Nice little dent right on the crease above the driver's front wheel arch and scuffed up paint on the front bumper.
Mother-in-law is now banished to driving only the Commodore battle wagon which, every time it gets damaged, only elicits a "whatevs bro" from me.
You ought to see my two Stags. None of my doing.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
