LOL! Read that completely wrong. I thought you paid $100 for a set of tyres!! I thought "Do you even grip?".
I got a screw in one once, drove on it for a while just tightened it when it was leaking lots lol.
Hahaha yeah i tightened the offending screw when i jacked it up to put some spare 17" i had sitting around (to match rolling radius') but found that my nuts were too big...
So i'm glad i found some cheap 19" tyres a few months ago.
Finally made a steel cargo barrier for the boot in the stagea (instead of the original leather one) as the wife was going for a bit of a drive with lots of stuff in the back.
For anyone who is interested, the top metal rod of the normal one is 13mm - I used a half inch (12.7mm) solid rod which clipped in just fine, with a 20mm by 20mm steel tube for the bottom, and 3.15mm thick 50mm by 50mm mesh welded between the two for the middle.. :-)
Ian
Well finally had a bit of shed time! Fitted up rs4s rear cradle and 2way lsd, and whiteline rear sway bar , adjustable camber arms front and rear, hicas lock bar , r33 rear brakes and t3 rotors to match front , greddy rear strut brace. Wired in full race ets pro altessa controler as a stand alone unit, got the recaros in and bolted up, slid some nice new wheels under with some substantial 265 rubber on the back , connected and mounted my innovate motorsports lambda meter and put in some jtc n1 coil overs, and put on carbon ganador mirrors
Now just a wheel align and all good , when we get a bit of cool weather ill go and do some more tunning and turn boost up and water/meth injectionpost-76904-0-45997100-1390659802_thumb.jpg
  • Like 1
Now just a wheel align and all good , when we get a bit of cool weather ill go and do some more tunning and turn boost up and water/meth injectionattachicon.gifimage.jpg
Such a shame you didn't get much done... :whistling:
Sounds like it'll be almost a different car! It's looking damn good too.
Nice! Did you find a lock bar that bolted straight up or did you have to do a cut and shut job on one to fit?
Fitment stance style with grip :) 18x10 +10 with a 265 on it very little stretch only -1.5 deg of camber , nice big contact area for grip, only rolled gaurds no pumping or manipulating ! A very happy boy
  • Like 1
My wagon is back in the shop as of this morning to sort out the exhaust (it's almost head-ache inducingly loud), some light-throttle tuning and a few small niggles here and there. Something was causing some restriction somewhere, so hopefully the exhaust sorts it out while still reducing volume. They're sourcing a new muffler from SMB, and apparently an SMB muffler has been used on a 500kW R33 that's still pretty quiet.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
