LOL! Read that completely wrong. I thought you paid $100 for a set of tyres!! I thought "Do you even grip?".
I got a screw in one once, drove on it for a while just tightened it when it was leaking lots lol.
Hahaha yeah i tightened the offending screw when i jacked it up to put some spare 17" i had sitting around (to match rolling radius') but found that my nuts were too big...
So i'm glad i found some cheap 19" tyres a few months ago.
Finally made a steel cargo barrier for the boot in the stagea (instead of the original leather one) as the wife was going for a bit of a drive with lots of stuff in the back.
For anyone who is interested, the top metal rod of the normal one is 13mm - I used a half inch (12.7mm) solid rod which clipped in just fine, with a 20mm by 20mm steel tube for the bottom, and 3.15mm thick 50mm by 50mm mesh welded between the two for the middle.. :-)
Ian
Well finally had a bit of shed time! Fitted up rs4s rear cradle and 2way lsd, and whiteline rear sway bar , adjustable camber arms front and rear, hicas lock bar , r33 rear brakes and t3 rotors to match front , greddy rear strut brace. Wired in full race ets pro altessa controler as a stand alone unit, got the recaros in and bolted up, slid some nice new wheels under with some substantial 265 rubber on the back , connected and mounted my innovate motorsports lambda meter and put in some jtc n1 coil overs, and put on carbon ganador mirrors
Now just a wheel align and all good , when we get a bit of cool weather ill go and do some more tunning and turn boost up and water/meth injectionpost-76904-0-45997100-1390659802_thumb.jpg
  • Like 1
Now just a wheel align and all good , when we get a bit of cool weather ill go and do some more tunning and turn boost up and water/meth injectionattachicon.gifimage.jpg
Such a shame you didn't get much done... :whistling:
Sounds like it'll be almost a different car! It's looking damn good too.
Nice! Did you find a lock bar that bolted straight up or did you have to do a cut and shut job on one to fit?
Fitment stance style with grip :) 18x10 +10 with a 265 on it very little stretch only -1.5 deg of camber , nice big contact area for grip, only rolled gaurds no pumping or manipulating ! A very happy boy
  • Like 1
My wagon is back in the shop as of this morning to sort out the exhaust (it's almost head-ache inducingly loud), some light-throttle tuning and a few small niggles here and there. Something was causing some restriction somewhere, so hopefully the exhaust sorts it out while still reducing volume. They're sourcing a new muffler from SMB, and apparently an SMB muffler has been used on a 500kW R33 that's still pretty quiet.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
