Fitted up a kakimoto R tonight. Thanks #@DaveM35 for the swap. Car sounds awesome.
Glad you like it mate! Thank you as well, I can't believe how quiet mine is now I forgot what a difference the old zorst made!
Nice to meet you Josh, can't wait to see the results after tuning
  • Like 1
Cracked open the metal polish and put in some elbow grease, showed the Nismo some love.
Still my car for another couple weeks so it's gotta be shiny
So shiny, looks awesome mate
After doing an intake pipe for #@Brick, and a false start with a silicone upper reducer bend; I made him a blanking plug for the resonance chamber on the back of the OEM reducer bend.
Figured if I was doing one, I might as well do two... :whistling:
10544996_10152577957682392_1605917192_n.10515032_10152577957997392_1365672219_n.
I honestly don't know if it's the placebo effect at work but the car seemed more aggressive on boost.
Later, Josh rang me to let me know he'd fitted his, and that he was now apparently hitting boost cut; which it hadn't done prior to fitting.
There has been no change in AFM clipping on mine; it still skirts juuuust below the cut point.
Perhaps the reduced turbulence on the back of the bend is improving flow? Not sure.
The thing I did notice after I'd removed the resonance chamber, was that it had 1/4 teaspoon of incredibly fine dust inside; almost like talc.
Would be worth removing & emptying if you still run the chamber on yours.
  • Like 1
I have done this on a few cars, it's nice having a lathe handy hey Dale. :P
I can't say I noticed a performance increase, the chamber is there to help smoothen any pulsation over the AFM hotwire, so it's probably just a voltage spike.
Always handy to have a lathe at your disposal mate, one of the (many) perks of the trade for sure. Even nicer to have some spare time to knock out a couple of simple jobs... :whistling:
Hadn't thought of the voltage spike; I wouldn't have expected the effect to be so pronounced TBH. It didn't change my expected AFM readings at all.
This is unrelated to thread but the exhaust clips got me geed up to post a vid of the TT Gallardo we did at work a couple months back
Stagea guys know cool and this is cool so thought I'd share.
First time linking to a vid and first time I've uploaded to YouTube so hope it works
  • Like 1
We can no longer be friends Dave.
So sad.
Got the Stagea back from the garage last weekend, after my AFM fault was cured. Had an electronic boost controller fitted with an AFR and boost gauge. Pretty pleased with the PLX gauge. Looks nice and very functional. I'll be fitting oil pressure/temp sensors to the gauge at some point too.
I also fit in the amp and sub in the boot but that is only a temp fit, held down in the boot with springs. Need to get a longer ground cable as the one I have is a little short. But I'll sort that when I get around to making a raised boot floor to cover the LPG kit which I plan to get fitted. I figure I'd be raising the boot floor by around 100mm, which then also gives me plenty of scope to build a number of compartments for tools and other bits.
I've finally added a stereo with Bluetooth capability to my car. It's another Alpine unit, but I decided I couldn't justify spending a massive wedge on a single-DIN stereo with touchscreen display if the BT tech was going to be old and unreliable. Alpine hadn't bothered to release anything new for that market in 2 or 3 years, and not many other brands either make something similar or something I like.
I used the opportunity to get some sound deadener put into all the doors too.
Love Bluetooth in the car. CCS did the work?
Thinking about using them for a new alarm; they seem very thorough.
Got the boot struts re-gassed to 1200nm. Why didn't I do this sooner? $96 very well spent if you actually use the boot.
Did you remove & check the ball ends on the body when the struts were out?
About 2 weeks after I had mine regassed I snapped one off.
Very annoying.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
