Worh the comparison i can see that now. What did it cost?
300$ for a set of headlights
120$ for the 3 pairs of halos
And about 1 or 2 hours of your time
(one of the smaller rings turns orange with the turn signal on the headlight with 3 halos)
  • Like 1
Power steering belt replaced on the 260, took 3 days lol. (Lazy b$%td)
940 came off, was shredding not completely foobah.
960 on hand..........too long.
925 on hand...........way too short.
Bought another 940.....................effin tight as to fit but works OK.
Hindsight suggests 945 or 950.
Amen.
GW
Failed a Warrant of Fitness with it. :( Leaking front left shock. Do these match any other model's OEM shock? I had a quick look through the suspension thread but everyone seems to be not married to accountants and they go straight to coilovers.
Part number 56110-7W026 is for the front left shock according to FAST.
From August 2004 on VQ25DD and VQ35DE RX Four models.
Not used on any other Nissan.
I got KS-ROM ECU today and replaced with OEM one. Will test the power output next week with my Blitz powermeter. Current my best record is 6.5s for 0-100km
attachicon.gifImageUploadedBySAU Community1434630026.869021.jpgattachicon.gifImageUploadedBySAU Community1434630011.402433.jpgattachicon.gifImageUploadedBySAU Community1434630044.119363.jpg
Nice, were you able to order it with your mods listed? Or was it just a random tune from someone else's car?
  • Like 2
absolutely random tune from someone's car. it is really hard for us to get specific tune from Japan
It is near impossible hence the question. Make sure you get it on a dyno sooner rather then later to at least make sure the tune is safe.. you never know what it could be tuned for. Maybe even different injector sizes
yes, it is true. but from what I know for KS-ROM, it is a light tune and it is suitable for factory car, not like impul and nismo ECU. anyway, i will try to figure out if the ECU is safety for my car or not.
currently I have EBC on my car that could avoid over boost, that is the biggest risk for unknown tuned ECU.
Edited by YangLIU
Talk to mark at MRC castle hill. See what he will charge juat for a quick dyno test. He has na awd dyno so woild be able to do it without pulling shafts etc
yup, i always do the service from MRC. thanks mate.
  • Like 1
Went to start the car this morning to go get a coffee and no start. It sounded like a fuel pump issue and sure enough it was! The DW301 was dead, only 2ish years old lol. Pulled it out and put 12V on it and its totally dead.
DW301
Ordered premium plates just for cosmetic reasons. South Australia premium plates look much better on Jap cars if you use a large rear (on the rear) + a normal rear (on the front).
I've also saved probably twice as much cash as i need to look at better tuning for the M35 plus i'm still holding onto the Manual dream.
Edited by Beregron
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
