Religious oil and filter change.. found an oil leak somewhere in the turbo vicinity below rocker cover but above boots.. *sigh*
oil return line maybe? Edited by Lakes101
Looks like it didnt seal correctly. .... some gasket goo will help this.
Today i installed front swaybar (hardest setting), daleo front brace & ox rear brace i picked up for a steal. (Yes i know ive done this twice before). I also installed 1 part of the dolphin intercooler piping as ill need to modify the oem turbo intercooler piping where it bolts to the turbo for the 2nd bit to attach. post-77821-14565528584997_thumb.jpgpost-77821-14565528763051_thumb.jpgpost-77821-14565528950884_thumb.jpgpost-77821-14565529034387_thumb.jpgpost-77821-14565529558829_thumb.jpg
  • Like 1
Did an oil change (only 6,500km late...) and had a quick look around for issues. I think I've identified the source of an annoying tinny rattling noise that's been going on for the past couple of years - the outer skin of the Y-pipe has corroded. My wife asked what the means and I gave her a big grin and said "new exhaust time!" I don't think she was amused, she'd rather just keep complaining it sounds too girly compared to our Commodore (which is a Mootec with a foghorn-spec pipe on it).
Also noticed the sway bar bushes look very dry and cracked, could this be the source of creaking under brakes/cornering sometimes? I ask because Scotty's mentioned it's likely to be the compression rod bushes and they're not where I'm expecting them to be and I'm too embarrassed to ask where they are. :blush2:
Furthermore, the tyres are getting low on tread so we're now at the "upsize or make do" crossroads. Has anyone run 235/50 R17s on stock M35 rims? Theoretically they'll fit on the rim and are close enough in rolling radius but they'll probably look quite bulgy.
I'd love to splash out a few thousand on a set of 18s but we're in the middle of renovations and preparing to sell a couple of houses so money's not exactly flowing right now. :(
Haha. follow the compression rod from the bottom of the hub Matt, back to the body, you can see the large bush taking the rearward load of the hub. Press it out and replace with a Superpro poly bush.
Ok cool, thanks. I've only done rod bushes (and every other front end one) on the Commodore previously and they run forward of the hub, I thought I was going nuts. Do they take much to press them out? I don't have a hydraulic press and had to get an engineer to do get out the Commie's LCA bushes.
I should also report that happily the outside temperature reading has started working again all by itself. Great success!
I got a set of 18s off a Skyline GT sport or something like that for about $600 with good tyres...e.g.
http://www.trademe.co.nz/motors/car-parts-accessories/wheels-tyres/alloy-wheels/auction-1042008275.htm
  • Like 1
Or get some 350Z rims and make some space for those big brakes Matt.
They look awesome on the Stag, perfect offset, hundreds for sale too.
Servicing the other half car yesterday , I got a good look at my wheels, different vantage point.
The clear coat has seen better days on the spokes.
So with a few hrs of daylight left I got into them with sand paper and metal polish.
Getting there
Not a perfect job but a damn sight better
Got two done before it was too dark , this morning the other two.
Not a fan of blingy blingy but its better than peeling clear, and will tide me over till I find something that will fill out the guards better.
  • Like 5
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
