Finally got my AMPerformance intake fitted, straight away noticed the extra flow.
Throttle more sensitive down low, less throttle needed to get the car rolling.
Haven't tested high rpm yet.
Thanks to Craig for fitting it, wasn't easy.
PITA to install. Money well earnt for Craig
Do you have a tunable ECU? I have a AM Performance Intake sitting in my garage and from what i have read they will max out injectors if it isn't tuned right. Will be interesting to see your results, what other mods have you done on your car
As most of you know, 7 weeks ago my car was stolen and written off. It has been a stressful and frustrating time, to have your car stolen from your driveway while your home is a felling I cannot describe.
I have tried to put it behind me and turn my negative into a positive, I tracked down another Stagea, while salvaging my old wreck. Got it through roadworthy and now it is registered in my name
It has been a roller coaster ride that I don't want anyone to have to go through. Now looking for the future
The Last pic of my Old Stag
At the salvage yard :(
Picking up my new Stagea from Sydney
At Vicroads registering it in my name
New Stagea is in my name :D
Edited by DrLui
  • Like 8
I do have an E-manage but not installed yet.
Also have fuel pump to install still.
Car has ATP high flow, 100 cell cat, Scottys dump and Legalis R straight through.
Goes pretty hard.
Once fuel pump is done I'll get it all checked on the dyno.
Way to go Luis with your new wagon. You're unstoppable
I had the am intake and did not max injectors. (Untuned). Its amazing what you car 'read'
Your not wrong there, but reading through the comments bellow
http://www.sau.com.au/forums/topic/414739-m35-am-performance-intake/page-2
I would rather wait until I have a tuneable ecu before installing it, it's not worth the risk imo. The standard intake works fine for what I have now
  • Like 2
Can anyone confirm if the V36 Y-pipe is a bolt-in affair with the rest of the PNM35 exhaust?
I doubt anything V36 is bolt on. The flanges on the Y pipe were supposed to be in the same spot, but they are not.
I have a set of V36 headers here, they would be a great upgrade over the stock log manifolds. Custom cat pipes are required though.
Bugger. Off to Yahoo Japan auctions then. I only need a Y-pipe at the moment, the outer wall on mine's rusted and the tinny rattling noise is driving me nuts.
I am not sure it would be accurate if you are basing it off my install.
The reason being that we first tested it on my PNM35 with V36 headers and aftermarket Z34 de-cat pipes which didn't marry up with the OEM V36 cat-back on my car. Then the V35 Berk HFC's were modified and made to fit.
I reckon that the V35 and V36 y-pipes would be interchangeable if using the OEM headers and cats. I did have the V36 y-pipe and exhaust on my PNM35 with OEM headers and V35/G35 Berk cats.
After the y-pipe? Can't be sure, but since the V36 y-pipe bolts up to PNM35 cats, I would be surprised if it didn't fit the rear section as well.
Do you have access to a cheap V36 y-pipe? If so, why not give it a go?
If not, you could just get a cheap stainless V35/G35 Y-pipe off ebay or maybe an OEM unit from a wrecker?
Edited by iamhe77
I don't have one, no. Unfortunately where I live I can find anything I want for my Commodore, but talk about V/M-series Nissans and everyone thinks you're some kind of weirdo.
I've found a V36 pipe in Hamilton (http://www.partsworld.co.nz/parts/nissan/skyline/3312_v36/67_engine+components/270111510) so I might send them an email and get some measurements. No doubt they'll charge a ludicrous amount for it.
Soo finally got scottys dump in, what a great bit of fab work, definately reccomended.
Changed the fuel pump/filter/oring in the hopes it would clear my lean code ( 0171 ) sadly it hasnt but still yet to run a constant supply, maybe that will do it.
And picked up a set of r34 gtt front brakes to keep me busy for the long weekend!
So not a cheap week for my stagea but damn it's good to drive now.
Got bad fuel so took it into work to have the mechanics drain it and also do a service cause I was feeling lazy.
A week later and many many $$$$ later the car has had the following done, some needed some preventative.
Found and fixed a small boost leak
2 front wheel bearings
Steering rack rebuild
New control arm bushes
New diff bushes
New sub frame bushes
Spark plugs
New compression rod bushes
Also found a faulty cool pack.
Plus a few other bits.
Now it is all done and wheel aligned just in time for double demerit points so it has been parked away for the weekend haha.
  • Like 2
New diff bushes
Spark plugs
New diff bushes
Spark plugs
josh how much did they charge you for labour on all the bushing mate? Looking at getting all mine done to. Did you run with OEM ones or superpro or the like? Will feel amazing to drive now mate I bet.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
