Yeah i feel the black head lining is a little too much. Would be different if i had black piller panels etc.
The upholstery and new liner will be done professionally. Not sure on cost for seats but got quoted 180 for the roof installed so thats a pretty good price. Essentially the interior will be black and beige/tan with burnt orange seats and silver highlights (door handle trims and gear stick surround).
The outside i am planning on doing a matt dark blue wrap with matt or gloss black wheels. Ill try and find a picture of the wrap for reference.
After putting up with a low idle for a week , yesterday took out throttle body to wash out with carb cleaner, gave it a good clean - hooray problem sorted.
Went for a good long drive last night to give it a good squirt, blew the passenger globe ! WTF its 6 months old.
Picked up a HID kid at 11, dismembered the front end and took the lights out. All complete by 13:30
While putting it all back together there is a whiff of coolant found that rad is weeping just near the cap :rant: . so now new rad time as soon as I order and it arrives.
  • Like 2
Fitted up a fire extinguisher today. Curse you Mighty Car Mods and your evil sidekick, Supercrap Auto!
Nice removable factory bracket on the non electric passenger seat so the extinguisher moves with the seat.
post-135423-0-20101400-1461413170_thumb.jpgpost-135423-0-00231200-1461413181_thumb.jpgpost-135423-0-39788000-1461413193_thumb.jpgpost-135423-0-74149800-1461413206_thumb.jpgpost-135423-0-36357900-1461413219_thumb.jpg
Yeah that's where they always split.
Think it happens to everyone eventually!
bought and fit headlight, it is 2nd one but near new, cant imagine it is over 10 ages old but still near new, compare with my old set.
now my world is clear again.
Edited by YangLIU
new part arrived yesterday :yes:
yet to do in the near future
exhaust modification
dump pipe
intercooler
intake
bc racing suspension
and new wheels
made as soon as the financial situation to give up :angry:
No big deal Josh.
You can get the 29mm recirc adapter and adapter plate from Nengun.
I used a Subaru adapter plate and just reamed the holes to realign them.
Just counter sink the plate and use counter sunk adapter bolts and take a nick off the side to clear the throttle body.
That's it.
It's well worth the install.
The valve travels so well, the intake recircs like it should.
No shudder, black smoke, dumping fuel.
Really smooth.
The Greddy is 40mm , Turbosmart 22mm, plus the Greddy FV is so adjustable with the two springs plus the wind in plunger.
By far the best thing I've done to this car so far.
  • Like 2
No big deal Josh.
That's it.
Really smooth.
I had a custom pipe welded up for $60, bought a couple of vac nipples to screw in and used a universal turbosmart kompact which had a 32mm base, easy peasy and asthetically good looking
Yes but to pay over 300 for one that doesn't bolt straight on against 189 for a turbosmart that does.....
adapter was easy to make an 8 mm aluminum sheet. but requires a little drilling, and grinding
the time it takes about an hour and the price of the adapter will be 2 €
Picked up a new driver seat today, happened upon it while checking out one of the local Up Garage locations...set me back a whole 20 usd
anyone happen to know the stock rail bolt size, I'm guessing 12mm but wanted to double check before I order a wrench, may just go ahead and pick up a ratchet set thoughHkC5bgbl.jpg
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
