Birds- I've been trying to work out since June how old you are??? You sure it don't wanna just tell me....but I figured your about 27-29 just going by your posts.
What part of NEVAAAAAAAAAAAAAAAAAA don't you understand :happy:
my gf is 23, I like the older ones, they know what to do :)
23?
I thought she was like 20?
Ah well all the better :)
EPIC WIN!
I don't think many people do till they hit 25. Up until then it's quantity not quality.
Hahaha!
Clutchy clutchy...do you think you'll be doing what you're doing now for the rest of your working life? Most don't. Career change in early-mid 20's = head start on life! Retirement age will no doubt raise to 70 once all the baby boomers hit their pensions. We're living healthier and longer too.
This is my plan, except kids. They cost too much.
I'm getting lost somewhere between the N and the heap of A's
I suppose you can keep your secrets behind your Count Duckula cape for now
